I end up asking for help on this forum since I tried multiple approaches to solve my problem but I could'nt find any solution... So apparently I have unmet dependencies and when following apt advise, running apt --fix-broken install returns :
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
libpython3.9-minimal libpython3.9-stdlib
The following packages will be upgraded:
2 to upgrade, 0 to newly install, 0 to remove and 229 not to upgrade.
3 not fully installed or removed.
Need to get 0 B/2 532 kB of archives.
After this operation, 490 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 477986 files and directories currently installed.)
Preparing to unpack .../libpython3.9-stdlib_3.9.5-3~20.04.1_amd64.deb ...
Unpacking libpython3.9-stdlib:amd64 (3.9.5-3~20.04.1) over (3.9.2-1+bionic2) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.9-stdlib_3.9.5-3~20.04.1_amd64.deb
(--unpack):
trying to overwrite '/usr/lib/python3.9/_sysconfigdata__linux_x86_64-linux-gnu.py', which is also in
package libpython3.9-minimal:amd64 3.9.2-1+bionic2
Preparing to unpack .../libpython3.9-minimal_3.9.5-3~20.04.1_amd64.deb ...
Unpacking libpython3.9-minimal:amd64 (3.9.5-3~20.04.1) over (3.9.2-1+bionic2) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.9-minimal_3.9.5-3~20.04.1_amd64.deb
(--unpack):
trying to overwrite '/usr/lib/python3.9/typing.py', which is also in package libpython3.9-stdlib:amd
64 3.9.2-1+bionic2
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Basically, I can't use apt anymore since I get similar error message every time. dpkg also gives me dependency errors.
I tried to reinstall Python with source code but got related errors... It appears I'm stuck.
I'd be really thankful for your help <3
