I started my computer two hours ago and was confused that my browser (Firefox) didn't work anymore. Took my some time and research to realize that my DNS server seems to fail. I don't know why it's not working anymore. On my last session I installed ProtonVPN client, maybe it misconfigured something? I have actually never done any changes to any DNS settings ever in my life before.
So how can I solve my problem that I can't browse? What I've found out so far:
Pinging e.g. 8.8.8.8 works, so there is definitely a connection to the internet (I'm writing here using TOR browser which works btw so I'm really online)
The DNS server to use is specified in /etc/resolv.conf. Beside a long comment there is just this:
nameserver 127.0.0.53 options edns0 trust-ad
So the DNS server is a local name server running on port 53. According to my research this seems to be the default value.
I found this command
lsof -Pn -iUDP:53to make sure that the name server is running (guess that's what it is doing? There seems to be no man page for this command...)COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME lollypop 3433 jonas 21u IPv4 529240 0t0 UDP 127.0.0.1:49435->127.0.0.53:53 lollypop 3433 jonas 22u IPv4 529816 0t0 UDP 127.0.0.1:43447->127.0.0.53:53 lollypop 3433 jonas 24u IPv4 529250 0t0 UDP 127.0.0.1:53369->127.0.0.53:53 lollypop 3433 jonas 26u IPv4 528227 0t0 UDP 127.0.0.1:39800->127.0.0.53:53 lollypop 3433 jonas 27u IPv4 527211 0t0 UDP 127.0.0.1:43076->127.0.0.53:53 lollypop 3433 jonas 28u IPv4 527215 0t0 UDP 127.0.0.1:51560->127.0.0.53:53 lollypop 3433 jonas 29u IPv4 529792 0t0 UDP 127.0.0.1:43262->127.0.0.53:53 lollypop 3433 jonas 30u IPv4 530442 0t0 UDP 127.0.0.1:38656->127.0.0.53:53 lollypop 3433 jonas 31u IPv4 529238 0t0 UDP 127.0.0.1:42753->127.0.0.53:53
I found also this command sudo systemctl status systemd-resolved to check whether the server is running
● systemd-resolved.service - Network Name Resolution
Loaded: loaded (/lib/systemd/system/systemd-resolved.service; enabled; vendor preset:>
Active: active (running) since Sun 2021-08-08 22:06:19 CEST; 1h 26min ago
Docs: man:systemd-resolved.service(8)
https://www.freedesktop.org/wiki/Software/systemd/resolved
https://www.freedesktop.org/wiki/Software/systemd/writing-network-configurati>
https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients
Main PID: 991 (systemd-resolve)
Status: "Processing requests..."
Tasks: 1 (limit: 9338)
Memory: 11.1M
CGroup: /system.slice/systemd-resolved.service
└─991 /lib/systemd/systemd-resolved
So it really looks like the DNS server is running right? But why can it then not lookup addresses?
Using dig google.com I only get the following error:
; <<>> DiG 9.16.1-Ubuntu <<>> google.com
;; global options: +cmd
;; connection timed out; no servers could be reached
I hope anyone can help me here? I would just like to reset it to Ubuntu's defaults as it was all the time before. Any maybe even someone got an idea what might have caused this problem?
