Until two days ago, using two monitors in Ubuntu 20.04 was no problem. However, since yesterday, this is not possible anymore, even though I did not change the cable setup or anything. Also, when I go to "Settings"-->"Displays", it shows me "Unknown Display" whereas previously it had showed me the two connected monitors. I have an Nvidia GPU built in, any help would be appreciated.
Edit 1: Interesting, this problem does not occur under Windows where I can use my two monitors without any problems. My setup is a tower PC, an Nvidia GeForce GT 610 is built in.
Edit 2: The problem is solved now, cf. the accepted answer.
Hermi
  • 95
Two monitors with Ubuntu 20.04 LTS - now with the Linux driver nouveau
I have a somewhat similar system [as the original poster]. I updated and upgraded my Ubuntu 20.04 LTS in a Dell m4800 with nvidia graphics.
After reboot it can still feed two screens, one internal monitor and a 40 inch TV. I have them 'side by side' and can move windows from the internal monitor to the TV with the touchpad.
But I noticed that the system had automatically turned off the proprietary driver and was using nouveau (the free Linux driver). The performance playing video is good, I did not notice any significant difference in quality.
It works also for the original poster to switch to the free Linux driver, nouveau, and it can be a good alternative also for other users who are affected by this problem. (Let us hope that there will soon be a working solution with a proprietary nvidia driver too.)
To switch the drive, go to "Software & Updates", then under "Additional Drivers" and finally choose the Nouveau driver.
Hermi
  • 95
sudodus
  • 47,684
This kind of problems is typically related to driver issues. Check if, in grub, booting to an earlier kernel solves the problem.
Also, identify when was the last boot
$ journalctl --list-boots
and update (output may well be in excess of what is needed, but it doesn't hurt)
$ zgrep "linux" /var/log/dpkg.log* | grep " install "
$ zgrep "nvidia" /var/log/dpkg.log* | grep " install "
In addition to posting this output, please post the output of
$ inxi -v 2
$ xrandr
$ ubuntu-drivers devices
If you don't have inxi and/or ubuntu-drivers you can install them with sudo apt install inxi ubuntu-drivers.
If you don't have the latest nvidia drivers, I suggest you install them with, e.g.,
$ sudo apt install nvidia-driver-470
and reboot.
