a
The above picture shows Canonical livepatch setting in software_properties_gtk. How do I enable/disable the Canonical Livepatch via command line?
Sun Bear
  • 3,014
I discovered that Canonical Livepatch is a SNAP App called canonical-livepatch.
On command-line, I discovered:
$ canonical-livepatch --help
Incorrect Usage. flag: help requested
NAME: canonical-livepatch - canonical livepatch client
USAGE: canonical-livepatch [global options] command [command options] [arguments...]
VERSION: 9.7.2
AUTHOR: Canonical Livepatch Team
COMMANDS: status show kernel's livepatch status enable enable livepatching on the machine disable disable livepatching on the machine refresh immediately download and apply any available livepatch config configure livepatching on the machine kernel-upgrade-required indicate whether a kernel upgrade is required help display help
GLOBAL OPTIONS: --version, -v print the version
To disable canonical-livepatch, I simply do:
$ sudo canonical-livepatch disable
Successfully disabled device. Removed machine-token: ################################
To enable canonical-livepatch, the command-line should write:
$ sudo canonical-livepatch enable MACHINE-TOKEN
where MACHINE-TOKEN is provided by canonical. However, I have not found a way to get MACHINE-TOKEN via command-line. It seems to be generated after Livepath is enable in the software_properties_gtk GUI and every enabling creates a unique MACHINE-TOKEN.
Update: Just discovered from this question that the MACHINE-TOKEN can be obtained from https://auth.livepatch.canonical.com/
Sun Bear
  • 3,014
