-1
when i use sudo dpkg -i code_1.58.2-1626300392_arm64.deb
then
(Reading database ... 99048 files and directories currently installed.)
Preparing to unpack code_1.58.2-1626300392_arm64.deb ...
Unpacking code:arm64 (1.58.2-1626300392) ...
dpkg: dependency problems prevent configuration of code:arm64:
 code:arm64 depends on libnss3 (>= 2:3.26).
 code:arm64 depends on apt.
 code:arm64 depends on libxkbfile1.
 code:arm64 depends on libsecret-1-0.
 code:arm64 depends on libgtk-3-0 (>= 3.10.0).
 code:arm64 depends on libxss1.
 code:arm64 depends on libgbm1.
dpkg: error processing package code:arm64 (--install): dependency problems - leaving unconfigured Processing triggers for gnome-menus (3.31.4-3) ... Processing triggers for desktop-file-utils (0.23-4) ... Processing triggers for mime-support (3.62) ... Processing triggers for shared-mime-info (1.10-1) ... Errors were encountered while processing: code:arm64
dpkg cannot automatically handle dependencies. Use apt instead.
sudo apt install ./code_1.58.2-1626300392_arm64.deb
Alternatively, if you already installed it using dpkg, you can get the missing dependencies with
sudo apt install -f
