14
I'm experiencing something weird today. I've been searching all over the internet, but I can't seem to find anybody who has the same problem.
I have Kubuntu 21.04 and Windows 11 installed in dual-boot.
Yesterday, i did a "cumulative update" for Windows 11, then i shut the computer down.
Today, I can't get GRUB to load. I tried entering the following command in windows command line but it didn't help
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
Some file name seems to have been corrupted or something. Here is a picture of the error message:
Error message
Can someone tell me how to fix this?
EDIT: So I managed to get grub back by using boot-repair BUT As soon as I booted in Windows 11 again, the problem reappeared (no windows update, just plain booting).
So I boot-repaired again, and as boot-repair basically reinstalls Grub, I had to reconfigure it for iommu (gpu isolation for VMs).
So for now, I can get to Kubuntu and work with my VMs but I am kind of nervous to try Windows 11 again, as configuring iommu takes time and I have a lot of work to do.
System specs:
  • I9-10900K
  • 64GB Corsair DDR4
  • 1TB Sambung EVO+ NVME SSD
  • AMD Radeon Pro W5700
  • Msi Z490-A Pro
Output of sudo efibootmgr -v (after fix)
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0003,0001
Boot0001* Windows Boot Manager  HD(1,GPT,41013caf-e980-464c-b214-4c6885f2bac7,0x800,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)..BO
Boot0003* ubuntu        HD(1,GPT,41013caf-e980-464c-b214-4c6885f2bac7,0x800,0x32000)/File(\EFI\UBUNTU\SHIMX64.EFI)
PS sorry for the poor quality of my English, as it is not may native language.
Thanks
VincentDrolet
  • 181
9 Answers9
I've investigated how to repair the grub boot. Finally, I found the solution with the following commands:
  1. sudo add-apt-repository -y ppa:yannubuntu/boot-repair
  2. sudo apt install -y boot-repair
  3. boot-repair
But, when I subsequently boot into Windows, and then I restart to login to Ubuntu, the same problem occurs.
I have BIOS version:
  • Windows 10 Pro Version 1909
  • Ubuntu 20.04.20 LTS
Greenonline
  • 2,182
In terminal, try running:
sudo update-grub
sudo apt update && sudo apt upgrade
I've been having this issue as well and have had to use boot-repair off a live usb. I've tried this after seeing that in the standard repo there seems to be an updated grub version I guess (grub2? Is this old or am I just dumb?). After updating and restarting, I still get the same error screen as you, but on the very last line, it now reads:
start_image() returned Invalid Parameter, falling back to default loader
With that, it now shows the general grub menu I'm used to, allowing me to select Windows 10 or Ubuntu again. This has been the closed I've gotten to a solution so without having to run boot-repair every time I'm down with Windows and need to get to Ubuntu. I hope this helps!
I've had the same issue after upgrading to Ubuntu 21.04 dual-booting with W10 but entering the command that you tried in an admin command line in windows seems to have solved it.
Marknes
I've got the same issue after upgrading Kubuntu to 21.04.
Booted from live USB, tried boot-repair with different options, it did not help.
It turned that my Acer PC:
  • Does not support booting via shimx64.efi, but supports grubx64.efi and refind_x64.efi.
  • Supports only boot record named "Windows Boot Manager" and ignores others.
The solution that worked for me:
  1. Boot from a suitable Linux live USB, for example Kubuntu installer USB. Open a terminal.
  2. Become root and install efibootmgr if needed:
     sudo -i
     apt install efibootmgr
  3. Check that the active boot record named "Windows Boot Manager" contains unwanted bootloader:
     efibootmgr --verbose
  4. Note the number of the active boot record. Its output format will be BootNNNN, where NNNN is the number that you will need to use in the subsequent efibootmgr commands for the --bootnum switch. In my case, the output was Boot0000, thus, the number used for the --bootnum switch was 0000.
  5. Remove the active boot record:
     efibootmgr --delete-bootnum --bootnum 0000
  6. Create a boot record with wanted bootloader at the place of just-removed boot record:
     efibootmgr --create --bootnum 0000 \
                --label 'Windows Boot Manager' \
                --loader '\EFI\ubuntu\grubx64.efi'
    or
                --loader '\EFI\refind\refind_x64.efi'
  7. Check that the boot record table looks good now:
  8. Reboot.
What worked for me was to name the FAT32 partition and then from windows terminal locate the ubuntu folder and just adding grubx64.efi.gbr
Naming your FAT32 partition (If you have already done this then ignore this part) :
Open Windows terminal as admin
  1. Chose Diskpart :
    C:\WINDOWS\system32> diskpart
  2. Find out the Disk number of your FAT32 partition
    DISKPART> list vol                    `
  3. Select Volume (Here 2 is an example volume number)
    DISKPART> sel vol 2                    `
  4. Naming the volume :
    DISKPART> assign letter=E:              `
  5. Exit Diskpart :
    DISKPART> exit                          `
Fixing the Grub :
  1. First
     C:\WINDOWS\system32> cd /d E:
  2. Then
     E:\> ls EFI
  3. Next
     E:\>cd EFI
  4. Next
     E:\EFI>cd ubuntu
  5. Next
     E:\EFI\ubuntu> touch grubx64.efi.gbr
  6. Now revert back to C Drive and set path to grub as default :
    E:\EFI\ubuntu> cd /d C:
    C:\WINDOWS\system32> bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
  7. Reboot Your Computer and it should work.
Greenonline
  • 2,182
I am also suffering from this issue running Windows 10 dual-booting with Ubuntu 20.04.3 LTS. Following the advice in this thread and others I've got things to the same point as FirDouglas. That is, grub fails to load initially, it then 'falls back to default loader' and I can select Ubuntu. This would be bearable if Ubuntu loaded up correctly. For whatever reason, it doesn't load the NVIDIA graphics driver (and possibly others but I haven't tested enough to find out) and the resolution is all kinds of messed up. Running boot-repair and restarting fixes everything. Loading into Windows breaks it again, sadly.
I don't have enough technical knowledge to fix it myself but, hopefully, this bit of information helps point to what the problem may be.
EDIT: I have managed to find a solution (that works for me, at least). That is, switching from shimx64.efi to grubx64.efi, which sounds like what FirDouglas has done except that I did it via the boot-repair package. Here's what I did: rather than choosing the recommended repair, I went into advanced options and, under "GRUB options", unchecked the "SecureBoot" option (it's checked by default despite Secure Boot being disabled in BIOS). I also checked "Purge GRUB before reinstalling it" to clear out what was there because I've been messing about with it - not sure if it's necessary in all cases. That's it, boot-repair now installs grubx64.efi and grub works just like it used to. You cannot run Secure Boot with this, obviously, but I will take that over having to run boot-repair every day.
I had the same problem and I found another question related to this.
I found out that my problem was probably some kind of Windows malfunctioning that was causing errors in GRUB loading. What actually worked for me was reinstalling GRUB for UEFI boot (and not for the Legacy one), following the arch wiki, and changing my BIOS settings from "Legacy+UEFI" to "UEFI".
Hope this will help!
I believe this has something to do with Microsoft trying to enforce secure boot. If I load the EFI shell from bios, and navigate to EFI\ubuntu, I was able to copy grubx64.efi over shimx64.efi. I'm assuming shimx64.efi isn't getting the correct parameters hence the error so just trick things by putting grubx65.efi there instead.This assumes you are not running secure boot, and I'm running windows 10 instead of 11.
I've been having the same error message. This is a dual-boot machine and it starts happening after I boot into Windows 11. Booting still works so it's not a blocker but just annoying. It can be mitigated by re-running grub-install, but subsequent booting into Windows will bring it back.
