This is my first question here, even if I've been lurking here for a long time.
I installed Ubuntu 21.04 next to windows 10 with hopes that a newer kernel would have better support for my problem. This was not the case.
- I've disabled fastboot on windows 10 (in "power options").
- I enabled the "Propietary drivers for devices (restricted)" sources when I installed.
- I disabled secure boot.
Here is my system information:
$ uname -a
Linux aspire-A515-56 5.11.0-26-generic #28-Ubuntu SMP Thu Jul 15 19:27:01 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Here are my specs for my network hardware.
$ sudo lshw -class network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 15
serial: 08:8f:c3:02:31:9e
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.11.0-26-generic duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.2.176 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:16 ioport:3000(size=256) memory:52004000-52004fff memory:52000000-52003fff
*-network UNCLAIMED
description: Network controller
product: MEDIATEK Corp.
vendor: MEDIATEK Corp.
physical id: 0
bus info: pci@0000:02:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm cap_list
configuration: latency=0
resources: iomemory:600-5ff iomemory:600-5ff iomemory:600-5ff memory:6003000000-60030fffff memory:6003100000-6003103fff memory:6003104000-6003104fff
And my rfkill feedback:
$ sudo rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
2: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
Thanks in advance for any insight that you can provide.
BTW: These are the sources I've looked into (and have not solved my problem):
