My wifi is working fine. However, when I try to connect using the ethernet, I get no connection. The ethernet is not even present in the settings. I'll list the output of some commands below, along with the things I tried.
ifconfig:
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:4e:cb:fe:fa  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 1904 bytes 174018 (174.0 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1904 bytes 174018 (174.0 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255 ether 52:54:00:44:21:93 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlp0s20f3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.3 netmask 255.255.255.0 broadcast 192.168.1.255 inet6 fe80::d111:7e77:a0f3:6d41 prefixlen 64 scopeid 0x20<link> inet6 fdd8:2918:dfd6:ef00:34c6:a262:f72d:577b prefixlen 64 scopeid 0x0<global> inet6 fdd8:2918:dfd6:ef00:2484:510:129e:4f1 prefixlen 64 scopeid 0x0<global> ether 84:1b:77:99:ba:ab txqueuelen 1000 (Ethernet) RX packets 24965 bytes 29016731 (29.0 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 13800 bytes 2260811 (2.2 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
iwconfig:
lo        no wireless extensions.
enp7s0 no wireless extensions.
wlp0s20f3 IEEE 802.11 ESSID:"HazemNetwork"
Mode:Managed Frequency:2.427 GHz Access Point: D8:29:18:DF:D6:F8
Bit Rate=58.5 Mb/s Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off Power Management:on Link Quality=58/70 Signal level=-52 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:1 Invalid misc:90 Missed beacon:0
virbr0 no wireless extensions.
virbr0-nic no wireless extensions.
docker0 no wireless extensions.
nmcli d:
DEVICE             TYPE      STATE         CONNECTION
wlp0s20f3          wifi      connected     HazemNetwork
docker0            bridge    connected     docker0
virbr0             bridge    connected     virbr0
p2p-dev-wlp0s20f3  wifi-p2p  disconnected  --
enp7s0             ethernet  unmanaged     --
lo                 loopback  unmanaged     --
virbr0-nic         tun       unmanaged     --
sudo lshw -c net:
  *-network
       description: Wireless interface
       product: Wi-Fi 6 AX201
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       logical name: wlp0s20f3
       version: 00
       serial: 84:1b:77:99:ba:ab
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.8.0-59-generic firmware=55.d9698065.0 QuZ-a0-hr-b0-55.u ip=192.168.1.3 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:16 memory:b2498000-b249bfff
  *-network DISABLED
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:07:00.0
       logical name: enp7s0
       version: 15
       serial: 8c:8c:aa:b5:61:4e
       width: 64 bits
       clock: 33MHz
       configuration: broadcast=yes driver=r8169 driverversion=5.8.0-59-generic latency=0 link=no multicast=yes
       resources: irq:18 ioport:3000(size=256) memory:b2204000-b2204fff memory:b2200000-b2203fff
  *-network DISABLED
       physical id: 3
       logical name: virbr0-nic
       serial: 52:54:00:44:21:93
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=tun driverversion=1.6 duplex=full link=no multicast=yes port=twisted pair speed=10Mbit/s
I tried using the network manager through this command: nm-connection-editor. And I added the ethernet connection. However, it didn't work as well.
I tried using this solution, and this one. But nothing worked.
I don't know how, but I have a feeling that this docker connection has something to do with it.
I hope that someone will find a solution. Thanks in advance...
It turns out that your Ethernet is disabled
This may help:
sudo ifconfig enp7s0 up
sudo nmcli dev set enp7s0 managed yes
Then restart NetworkManager:
sudo systemctl restart NetworkManager
Greenonline
  • 2,182
We can connect to the Internet via your phone's USB modem or directly plug in the cable for convenience. Then
sudo apt update
sudo apt install -y git build-essential
git clone https://github.com/lwfinger/rtw89.git
cd rtw89
make
sudo make install
sudo mkdir /usr/lib/firmware/rtw89
sudo cp  rtw8852a_fw.bin  /usr/lib/firmware/rtw89/
sudo modprobe rtw89pci
After these steps, you can select Internet in the Wi-Fi menu.
