I have a 320GB hp-mini netbook, which originally had 2 partitions (C: ~300GB, and D:(recovery) ~20GB). I shrank the C: drive, and created a 50GB unallocated partition, which i want to use for my Ubuntu 12.04 installation, but on loading Ubuntu via USB, I'm stuck as to how to accomplish this.
Asked
Active
Viewed 6,296 times
- Boot with live usb
- There will be screen asking for install options like
install along with windows 7,install ubuntu as only OSetc. Choose Do something else option at the end. - Now partition tool will open. You can see the unallocated space. Select that and then click on
Add. - Now we will add
SWAPpartition. Give disk space value as1024MB(1GB) or 2GB. If you have good amount of RAM (~2GB), 1GB swap space is enough. SelectSWAPin file system dropdown.Press "OK". - Now again continue previous step for the rest free space. This time select filesytem as
ext4and mount point as/. - Check in partition tool window, grub installation location is same as your hard disk not your usb disk. (most likely
bootloader location -> in sda ...) - Now go ahead and installation will finish in minutes.
Note: Don't enable downloading of 3rd party apps and update in previous screen. Better don't connect to internet while installing.Good luck. Let us know how it went.
Web-E
- 21,716
