On Ubuntu 21.04 I'm unable to get hylafax 6.0.7 to successfully probe two different USB modems: a USRobotics 5637 and a generic "USB 2.0 56K Modem" with Conexant chipset.
I've gotten hylafax-server installed and appended the following to /etc/udev/rules.d/50-myusb.rules so that Ubuntu would allow writes to the modem:
KERNEL=="ttyUSB[0-9]*",MODE="0666"
KERNEL=="ttyACM[0-9]*",MODE="0666"
- Is this necessary?
I get the following output when cuing both modems [ttyACM0 is USR5637, ttyACM1 is "USB 2.0 56K Modem"]:
figs@thinkpad:~$ cu -l ttyACM0
Connected.
at+fclass=?
0,1,8
OK
Disconnected.
figs@thinkpad:~$ cu -l ttyACM1
Connected.
at+fclass=?
0,1,1.0,2,8
OK
Disconnected.
figs@thinkpad:~$
- Both modems support Fax Class 1 to work with Hylafax.
Here are the permissions of the two modems, mounted at /dev/:
crw-rw-rw- 1 root dialout 166, 0 Jul 22 19:35 ttyACM0
crw-rw-rw- 1 root dialout 166, 1 Jul 22 19:36 ttyACM1
- Both modems have read & write access and are members of dialout.
When I run probemodem, both modems hang:
figs@thinkpad:/dev$ sudo probemodem
Serial port that modem is connected to []? ttyACM0
Hmm, there does not appear to be an fuser command on your machine.
This means that I am unable to ensure that all processes using the
modem have been killed. I will keep going, but beware that you may
have competition for the modem.
Now we are going to probe the tty port. This takes a few seconds,
so be patient. Note that if you do not have the modem cabled to
the port, or the modem is turned off, this may hang (just go and
cable up the modem or turn it on, or whatever).
Probing for best speed to talk to modem: 38400
ttyACM0 (USR5637) physical data lights blink briefly, and then this hangs for upwards of 1 day before I give up and kill the process.
ttyACM1 ("USB 2.0 56K Modem") does the same:
Serial port that modem is connected to []? ttyACM1
Both modems respond to the query with
cubut will not completeprobemodem.probemodemdeclares thatfuseris not installed, however I issued thefusercommand and it is definitely present despite not appearing in the synaptic gui, or giving any output declaring such fromapt-get install fuser.
- How do I get
probemodemto successfully probe the modem? Are permissions messed up somewhere? Elsewhere on the internet are reports of successfully using USR5637... do I need to change something somewhere?
Did I miss something or should this work? I'm sort of a noob at more advanced Linux undertakings and I'm at a loss as to how to get hylafax running with a USB modem.
