Disclaimer: pretty new to Linux
Relevant system specs:
Motherboard: MSI B450 Tomahawk Max
CPU: AMD Ryzen 9 3950X (no iGPU)
PCIe slot 0: Nvidia 2070 Super (1x monitor connected)
PCIe slot 1: AMD RX 550X (2x monitor connected)
OS: Ubuntu 20.04.2 LTS
I'm following a noob's guide on how to set up a Windows virtual machine with a passthrough GPU for playing games, using xubuntu as a hypervisor instead of Debian which was used in the guide. All steps up to isolating the Nvidia GPU are fine, but when I actually isolate the GPU using vfio my AMD GPU seems to be disabled or at least not used, and I am left with a (on but) black screen on all monitors. To get the screens to display again I have to disable IOMMU in my BIOS settings, then I can disable vfio and re-enable IOMMU.
I tried swapping the graphics cards, which for some reason messed up the ACS so each GPU couldn't be properly isolated, so that can't be done.
I tried following the answers to this similar question, however when I generated the xorg config I ended up with three separate GPU sections, each one assigned to each connected screen. Furthermore, the AMD GPUs are on the top, which would give them priority in my logic.
Section "Device"
Identifier "Card0"
Driver "amdgpu"
BusID "PCI:37:0:0"
EndSection
Section "Device"
Identifier "Card1"
Driver "amdgpu"
BusID "PCI:37:0:1"
EndSection
Section "Device"
Identifier "Card2"
Driver "nouveau"
BusID "PCI:38:0:0"
EndSection
I foolishly tried deleting card2 and its' connected display which bricked my system and forced me to reinstall.
Since I'm pretty new to linux and this is my first time diving into xorg.conf, now I'm stumped. How do I change the default GPU used by the OS, from slot 0 to slot 1?
Relevant, the output for lspci -nn | grep vga is
25:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] [1002:699f] (rev c7)
26:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU104 [GeForce RTX 2070 SUPER] [10de:1e84] (rev a1)
and find /sys/kernel/iommu_groups/ -type l confirms that the GPU is the only one in its IOMMU group.
First time asking, let me know if I've missed anything or made any mistakes. Sorry for lack of understanding, feel free to explain to me like I'm 5.
