I have an Ubuntu 20.10 system in a dualboot with Windows 10. It has been working for about the past 8 months, but suddenly today it no longer boots from Grub. Immediately after selecting Ubuntu from the drop down menu my laptop switches to an illuminated but black screen and sits there forever. My laptop is a Lenovo Yoga 720 15". The longest I let it sit without powering it off was 30 minutes. I tried to use boot-repair on a live-USB, but that did not fix anything. It gave me the following link: https://paste.ubuntu.com/p/QfkxbrnmNX/
In Grub I can select advanced options for Ubuntu. If I select Ubuntu, with Linux 5.8.0-59-generic only two lines display on the screen:
Loading Linux 5.8.0-59-generic ...
Loading initial ramdisk ...
The same result occurs when in advanced options if I select Linux 5.8.0-59-generic(recovery).
I can successfully boot the system only when using 5.8.0-55-generic.
Has anyone faced this issue before, or has any recommendations on how to fix it?
Any help is greatly appreciated!
Update #1: I am currently using this workaround. It means I have to press the return key twice on boot-up instead of just once, How can I boot with an older kernel version?, but it looks like I may have run across a bug.
Update #2: Running suggested comment and output:
(base) tyler@tyler-desktop:~$ ls -al /boot
total 204836
drwxr-xr-x 5 root root 4096 Jul 16 20:44 . drwxr-xr-x 23 root root 4096 Apr 30 16:15 .. -rw-r--r-- 1 root root 248155 Jun 1 02:57 config-5.8.0-55-generic -rw-r--r-- 1 root root 248155 Jun 16 18:11 config-5.8.0-59-generic drwxr-xr-x 4 root root 16384 Dec 31 1969 efi drwxr-xr-x 4 root root 4096 Jul 18 14:30 grub drwxr-xr-x 5 root root 4096 Jan 20 14:02 grub.bak lrwxrwxrwx 1 root root 27 Jun 22 17:47 initrd.img -> initrd.img-5.8.0-59-generic -rw-r--r-- 1 root root 54119063 Jul 5 19:46 initrd.img-5.8.0-55-generic -rw-r--r-- 1 root root 115559351 Jul 16 20:44 initrd.img-5.8.0-59-generic lrwxrwxrwx 1 root root 27 Jun 22 17:47 initrd.img.old -> initrd.img-5.8.0-55-generic -rw-r--r-- 1 root root 182704 Aug 18 2020 memtest86+.bin -rw-r--r-- 1 root root 184380 Aug 18 2020 memtest86+.elf -rw-r--r-- 1 root root 184884 Aug 18 2020 memtest86+_multiboot.bin -rw------- 1 root root 5654214 Jun 1 02:57 System.map-5.8.0-55-generic -rw------- 1 root root 5654841 Jun 16 18:11 System.map-5.8.0-59-generic lrwxrwxrwx 1 root root 24 Jun 22 17:47 vmlinuz -> vmlinuz-5.8.0-59-generic -rw------- 1 root root 13824992 Jun 1 03:01 vmlinuz-5.8.0-55-generic -rw------- 1 root root 13825888 Jun 16 18:20 vmlinuz-5.8.0-59-generic lrwxrwxrwx 1 root root 24 Jun 22 17:47 vmlinuz.old -> vmlinuz-5.8.0-55-generic
Update #3: Again runnning suggested input:
(base) tyler@tyler-desktop:~$ sudo update-initramfs -c -k 5.8.0-59-generic
[sudo] password for tyler:
update-initramfs: Generating /boot/initrd.img-5.8.0-59-generic
I: The initramfs will attempt to resume from /dev/nvme0n1p5
I: (UUID=53453367-1200-4da4-85dc-38594b9965a7)
I: Set the RESUME variable to override this.
total 204836
drwxr-xr-x  5 root root      4096 Jul 19 18:25 .
-rw-r--r--  1 root root 115558409 Jul 19 18:25 initrd.img-5.8.0-59-generic
Update #4:
(base) tyler@tyler-desktop:~$ grep -i compress /etc/initramfs-tools/initramfs.conf
 # Amount of RAM to use for RAM-based compressed swap space.
 # COMPRESS: [ gzip | bzip2 | lz4 | lzma | lzop | xz ]
COMPRESS=lz4
(base) tyler@tyler-desktop:~$ grep -v "#" /etc/modules
If there was an expected output from the second input, there was nothing.
Update #5: More outputs:
(base) tyler@tyler-desktop:~$ grep -i resume /etc/default/grub
(base) tyler@tyler-desktop:~$ cat /etc/initramfs-tools/conf.d/resume
cat: /etc/initramfs-tools/conf.d/resume: No such file or directory
(base) tyler@tyler-desktop:~$ grep -i swap /etc/fstab
# swap was on /dev/nvme0n1p5 during installation
UUID=53453367-1200-4da4-85dc-38594b9965a7 none            swap    sw              0       0
Update #6:
(base) tyler@tyler-desktop:~$ cat /etc/initramfs-tools/initramfs.conf
# initramfs.conf
# Configuration file for mkinitramfs(8). See initramfs.conf(5).
# Note that configuration options from this file can be overridden
# by config files in the /etc/initramfs-tools/conf.d directory.
MODULES: [ most | netboot | dep | list ]
most - Add most filesystem and all harddrive drivers.
dep - Try and guess which modules to load.
netboot - Add the base modules, network modules, but skip block devices.
list - Only include modules from the 'additional modules' list
MODULES=most
BUSYBOX: [ y | n | auto ]
Use busybox shell and utilities. If set to n, klibc utilities will be used.
If set to auto (or unset), busybox will be used if installed and klibc will
be used otherwise.
BUSYBOX=auto
COMPCACHE_SIZE: [ "x K" | "x M" | "x G" | "x %" ]
An empty value - compcache isn't used, or added to the initramfs at all.
An integer and K (e.g. 65536 K) - use a number of kilobytes.
An integer and M (e.g. 256 M) - use a number of megabytes.
An integer and G (e.g. 1 G) - use a number of gigabytes.
An integer and % (e.g. 50 %) - use a percentage of the amount of RAM.
You can optionally install the compcache package to configure this setting
via debconf and have userspace scripts to load and unload compcache.
COMPCACHE_SIZE=""
COMPRESS=lz4
NFS Section of the config.
DEVICE: ...
Specify a specific network interface, like eth0
Overridden by optional ip= or BOOTIF= bootarg
DEVICE=
NFSROOT: [ auto | HOST:MOUNT ]
NFSROOT=auto
RUNSIZE: ...
The size of the /run tmpfs mount point, like 256M or 10%
Overridden by optional initramfs.runsize= bootarg
RUNSIZE=10%
Update#7: Stuck directories that might be causing an issue
(base) tyler@tyler-desktop:~/Downloads$ rm -r ventoy-1.0.46
rm: cannot remove 'ventoy-1.0.46': Read-only file system
(base) tyler@tyler-desktop:~/Downloads$ rm ventoy-1.0.46-linux.tar.gz
rm: cannot remove 'ventoy-1.0.46-linux.tar.gz': Read-only file system
Your initrd.img-5.8.0-59-generic ramdisk file is corrupt, and that's why you can't boot to the -59 kernel.
See the file sizes and mod dates in the following two ramdisk files in /boot...
The fix...
Boot to the -55 kernel, open a terminal and type the following commands:
ls -al /boot # confirm new file size for initrd.img-5.8.0-59-generic
reboot # to the normal -59 kernel
Update #1:
To check your file system...
  • boot to a Ubuntu Live DVD/USB in “Try Ubuntu” mode
  • open a terminal window by pressing Ctrl+Alt+T
  • type sudo fdisk -l
  • identify the /dev/sdXX device name for your "Linux Filesystem"
  • type sudo fsck -f /dev/sdXX, replacing sdXX with the number you found earlier
  • repeat the fsck command if there were errors
  • type reboot
heynnema
  • 73,649
