I am running in 64-bit mode, trying to launch adobe fireworks. Having previously fixed this error ERROR: ld.so: object '/usr/$LIB/libgamemodeauto.so.0' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored. with: https://github.com/FeralInteractive/gamemode/issues/254#issuecomment-643648779
The log:
Running gamemoderun /home/hutber/.local/share/lutris/runners/wine/lutris-6.10-7-x86_64/bin/wine /mnt/users/Games/Games/fireworks/drive_c/Program Files (x86)/Adobe Fireworks CS6/Fireworks.exe
Initial process has started with pid 382179
Start monitoring process.
gamemodeauto:
wineserver: using server-side synchronization.
Monitored process exited.
Initial process has exited (return code: 13568)
All monitored processes have exited.
Exit with returncode 13568
I also have lib32-libldap installed as suggested in other posts:
sudo apt-get install libldap-2.4-2:i386
Reading package lists... Done
Building dependency tree
libldap-2.4-2:i386 is already the newest version (2.4.49+dfsg-2ubuntu1.8).
libldap-2.4-2:i386 set to manually installed.
0 to upgrade, 0 to newly install, 0 to remove and 208 not to upgrade.
