So its been a long time dream of mine to run Fireworks on Linux I assume somehow I am running the wrong version? gamemode is already the newest version (1.5.1-0ubuntu3.1).
Running with
  • Lutris: 0.5.8.3
  • Kernel: 5.8.0-53-generic
  • Wine version: lutris-6.10-7-86_64
  • DKVK version: v1.7.3L-03f11ba
Error Log
Running gamemoderun /home/hutber/.local/share/lutris/runners/wine/lutris-6.10-7-x86_64/bin/wine /mnt/users/Games/Games/fireworks/drive_c/Program Files (x86)/Adobe Fireworks CS6/Fireworks.exe
Initial process has started with pid 251133
Start monitoring process.
gamemodeauto:
ERROR: ld.so: object '/usr/$LIB/libgamemodeauto.so.0' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
wineserver: using server-side synchronization.
Monitored process exited.
Initial process has exited (return code: 13568)
All monitored processes have exited.
Exit with returncode 13568
Yeah so you're missing the 32bit libs. Remove gamemode (apt remove gamemode --autoremove), and download the Debian packages:
https://packages.debian.org/sid/amd64/gamemode/download
https://packages.debian.org/sid/amd64/gamemode-daemon/download
https://packages.debian.org/sid/amd64/libgamemode0/download
https://packages.debian.org/sid/amd64/libgamemodeauto0/download
https://packages.debian.org/sid/i386/libgamemode0/download
https://packages.debian.org/sid/i386/libgamemodeauto0/download
then install all .deb's with this command:
apt install -f path/to/gamemode.deb path/to/gamemode-daemon.deb ... This should fix your problem.
Taken from: https://github.com/FeralInteractive/gamemode/issues/254#issuecomment-643648779
I followed @jamie-hutber's answer, but I believe a cleaner way to do this would be to just install the missing i386 packages, instead of uninstalling the amd64 packages and then downloading them manually.
Just run this:
sudo apt install libgamemode0:i386 libgamemodeauto0:i386
And the 32 bit libraries will be added alongside the 64 bit libraries. I tested it with games that already worked (with that error in Lutris logs), and they are working fine.
