Here are the install commands I entered. Why is this not working?
$ sudo apt install bitwig-studio-3.3.11.deb
Reading package lists... Done
Building dependency tree... Done
E: Unable to locate package bitwig-studio-3.3.11.deb
E: Couldn't find any package by glob 'bitwig-studio-3.3.11.deb'
$ sudo apt install /bitwig-studio-3.3.11.deb
E: Unsupported file /bitwig-studio-3.3.11.deb given on commandline'
Nmath
  • 12,664
Your syntax is incorrect.
If you downloaded a .deb from the internet and you wish to install it with apt, you must cd to the directory where the .deb file is located.
Then you need to run sudo apt install ./yourdebfile.deb.
You should run sudo apt update before any other commands in apt to make sure that your package manager is up-to-date with the most current list of software. Otherwise you can encounter dependency issues.
Note that the . must go before the /.
Nmath
  • 12,664
