I have already tried multiple versions of nvidia-driver (360, 390, 460) - but with all of them I get following when I run nvidia-smi:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Here are my hardware and software details:
~$ dkms status
nvidia, 460.80, 5.8.0-59-lowlatency, x86_64: installed
~$ cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 42 model name : Intel(R) Celeron(R) CPU B815 @ 1.60GHz stepping : 7 microcode : 0x2f cpu MHz : 1596.389 cache size : 2048 KB physical id : 0 siblings : 2 core id : 0 cpu cores : 2 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave lahf_lm epb pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm arat pln pts md_clear flush_l1d vmx flags : vnmi preemption_timer invvpid ept_x_only flexpriority tsc_offset vtpr mtf vapic ept vpid unrestricted_guest bugs : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs itlb_multihit bogomips : 3192.76 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management:
processor : 1 vendor_id : GenuineIntel cpu family : 6 model : 42 model name : Intel(R) Celeron(R) CPU B815 @ 1.60GHz stepping : 7 microcode : 0x2f cpu MHz : 1596.380 cache size : 2048 KB physical id : 0 siblings : 2 core id : 1 cpu cores : 2 apicid : 2 initial apicid : 2 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave lahf_lm epb pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm arat pln pts md_clear flush_l1d vmx flags : vnmi preemption_timer invvpid ept_x_only flexpriority tsc_offset vtpr mtf vapic ept vpid unrestricted_guest bugs : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf mds swapgs itlb_multihit bogomips : 3192.76 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management:
~$ lspci -nn | grep VGA 00:02.0 VGA compatible controller [0300]: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller [8086:0106] (rev 09) 01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF119M [GeForce GT 520M] [10de:1050] (rev a1)
~$ uname -r 5.8.0-59-lowlatency
My PC is a Acer TravelMate 5360, and I'm running Ubuntu Studio 20.04 LTS. If you need any more details to tell me the right driver version, please just let me know and I'll add them !
TheEagle
  • 153
Use the recommended version only -and- don't forget to disable Secure Boot in BIOS, if applicable.
For an old 520M only the long term support branch has support for it currently, i.e., the 390.xx drivers.
You should be able to use it until Nvidia cuts the support. Be aware that it may happen sooner than expected.
ChanganAuto
  • 15
  • 23
