Possible Duplicate:
Compiz ( or even compositing in general) is not starting up when I login. Solution?
I have set the bottom left corner to window scale and the bottom right corner to show desktop. These effects do not work after login/boot. I have to open ccsm, remove the binding, click OK, reset the binding, click OK again and then it works. And then I have to do the same thing for the other corner. When I reboot the settings again won't work, although they are clearly activated and shown correctly in ccsm.
Everything worked fine under 11.10 so I don't know what to do. My computer is Asus 1215n with a fresh install of 12.04 64bit and bumblebee.
So far I tried putting the compiz --replace command in the startup applications, but while this worked once, it did not work afterwards anymore so I am back to square 1.
user62492
