I have a remote VPS with Ubuntu 20.04 which worked well yesterday. Today I found out the whole disc is read only. I can not write anymore nor as sudo nor the root. After the search I found command which should fix it https://askubuntu.com/a/1273263/568046
sudo ntfsfix /dev/sda2
This command throws me an error:
Mounting volume... NTFS signature is missing.
FAILED
Attempting to correct errors... NTFS signature is missing.
FAILED
Failed to startup volume: Invalid argument
Trying the alternate boot sector
Unrecoverable error
Volume is corrupt. You should run chkdsk.
Command chkdsk does not exist. After this command all programs are dead. I can run commands like systemctl status apache2 but can not start it any more. Does somebody know what it means? Thanks for any help.
