I am wanting to update from Ubuntu 20.10 to 21.04.
When I first tried I was getting an error:
W: GPG error: http://ddebs.ubuntu.com groovy Release: The following signatures were invalid: EXPKEYSIG C8CAB6595FDFF622 Ubuntu Debug Symbol Archive Automatic Signing Key (2016) <ubuntu-archive@lists.ubuntu.com>
E: The repository 'http://ddebs.ubuntu.com groovy Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ddebs.ubuntu.com groovy-updates Release: The following signatures were invalid: EXPKEYSIG C8CAB6595FDFF622 Ubuntu Debug Symbol Archive Automatic Signing Key (2016) <ubuntu-archive@lists.ubuntu.com>
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ddebs.ubuntu.com groovy-proposed Release: The following signatures were invalid: EXPKEYSIG C8CAB6595FDFF622 Ubuntu Debug Symbol Archive Automatic Signing Key (2016) <ubuntu-archive@lists.ubuntu.com>
Which seems that the key has expired. (Shrug)
I fixed it by doing this:
sudo apt install --reinstall ubuntu-dbgsym-keyring
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys F2EDC64DC5AEE1F6B9C621F0C8CAB6595FDFF622
sudo apt-get update
But it only got rid of that part.
When I try to sudo dist-upgrade this happens:
 sudo apt dist-upgrade
[sudo] password for me:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  dh-python
0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
So I don't understand why it isn't updating to 21.04
Please, someone. Thanks in advance.
You're not using the correct command.
The command you should run is sudo do-release-upgrade .
apt dist-upgrade is something entirely different.
See: What is "dist-upgrade" and why does it upgrade more than "upgrade"?
Nmath
  • 12,664
