I frequently need to back up a source disk to multiple target disks. At the moment the workflow is rsync from source to target1 then dd clone target1 to target2.
It would be lovely if I could rsync from source to target1+target2 sequentially in the same read operation to greatly speed things up. Read the file into memory one time and write it to two separate hard drives in grand synchrony.
Is there perhaps a way to have rsync read the file into memory and pipe the output to two write operations simultaneously? Doesn't have to be rsync but that'd be greatly preferred.
- 53
Putting together info from several sources, there are a few options.
The conclusion is that only with command parallel you might get what you want, see below.
Important notes:
- I have made tests with
cpfor copying. You should also consider speedups (or down!) obtained withrsyncvscpor other alternative commands, combined withparallel. - I have tested copying only one file. Results might change if copying many files (e.g., combining a few large files, as you need, with many other small files and subdirectories).
For each of the options, I have tested both
time <option #N, copying to one target>
time <option #N, copying to two targets>
to get a comparison, with a file of 1.2Gb. Moreover, in some cases I tested two or three times the same command, to assess the dispersion in the results. I did not compute averages and standard deviations, but the results are obvious.
This is what I got under the testing conditions specified above, with brief comments. I have concatenated in a single row the results of multiple tests, whenever available.
The base case:
$ time cp -p source/file1 target1/
real 0m0,846s 0m0,680s 0m0,659s
user 0m0,000s 0m0,001s 0m0,016s
sys 0m0,777s 0m0,662s 0m0,643s
The copying options:
Option
parallel$ parallel cp -p source/file1 ::: target1/ real 0m0,745s 0m0,740s user 0m0,121s 0m0,108s sys 0m0,609s 0m0,619s$ parallel cp -p source/file1 ::: target1/ target2/ real 0m0,794s 0m0,860s user 0m0,116s 0m0,134s sys 0m1,300s 0m1,380s
Option
tee(appending> /dev/nullto avoid output tostdout)$ tee target1/file1 < source/file1 > /dev/null real 0m0,874s 0m1,040s 0m1,028s user 0m0,160s 0m0,172s 0m0,137s sys 0m0,714s 0m0,868s 0m0,887s$ tee target1/file1 target2/file1 < source/file1 > /dev/null real 0m1,802s 0m1,680s 0m1,833s user 0m0,136s 0m0,212s 0m0,197s sys 0m1,642s 0m1,468s 0m1,619s
Copying to two
targets roughly doubles the time for onetarget, which is slightly larger than the time for the base case.Option
xargs$ echo target1 | xargs -n 1 cp -p source/file1 real 0m0,666s user 0m0,021s sys 0m0,646s$ echo target1 target2 | xargs -n 1 cp -p source/file1 real 0m1,197s user 0m0,018s sys 0m1,173s
Copying to two
targets roughly doubles the time for onetarget, which is similar to the time for the base case.Option
find$ find target1 -exec cp -p source/file1 {} \; real 0m2,167s user 0m0,017s sys 0m1,627s$ find target1 target2 -exec cp -p source/file1 {} ; real 0m3,905s user 0m0,020s sys 0m3,185s
Copying to two
targets roughly doubles the time for onetarget, which is much larger than the time for the base case... a clear loser.
Sources for "multiple copying":
- https://www.cyberciti.biz/faq/linux-unix-copy-a-file-to-multiple-directories-using-cp-command/
- How to copy a file to multiple folders using the command line?
- https://stackoverflow.com/questions/195655/how-to-copy-a-file-to-multiple-directories-using-the-gnu-cp-command
Sources for performance cp vs. rsync:
- https://unix.stackexchange.com/questions/91382/rsync-is-very-slow-factor-8-to-10-compared-to-cp-on-copying-files-from-nfs-sha
- https://lwn.net/Articles/400489/
- https://superuser.com/questions/1170636/why-is-there-a-write-speed-difference-between-dd-cp-rsync-and-macos-finder-to
- What's the difference between ` cp ` and ` rsync `?
rsync has a batch mode you could experiment with. When you do an rsync --write-batch=foo from to it will do the usual copying, but also replicate the instructions and data into file foo. If instead of a file this is a fifo you can use a second rsync in parallel to read the fifo and do a new rsync to a different destination. Obviously, the new destination must be sufficiently similar to the original to make sense.
For example, over a network you might try
mkfifo myfifo
ssh remotec 'rsync -av --read-batch=- destc' <myfifo &
sleep 1
rsync -av --write-batch=myfifo srca/ remoteb:destb
--read-batch cannot be used with a remote:destc style destination.
- 3,444
