I recently upgraded the kernel to version 5.13.0-051300-generic on my Tuxedo laptop equipped with Ubuntu 20.04. I am now trying to install the headers linux-headers-5.13.0-051300-generic_5.13.0-051300.202106272333_amd64.deb. If I try to do so with the command sudo apt install ./linux-headers-5.13.0-051300-generic_5.13.0-051300.202106272333_amd64.deb, I get the following error message:
 linux-headers-5.13.0-051300-generic : Depends: libc6 (>= 2.33) but 2.31-0ubuntu9.3 is to be installed
I then tried to install libc6_2.33-0ubuntu5_amd64.deb with the same command but get the following:
The following packages will be upgraded:
  libc6
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
  libc-bin
1 upgraded, 0 newly installed, 68 to remove and 0 not upgraded.
Need to get 0 B/2,690 kB of archives.
After this operation, 2,034 MB disk space will be freed.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
To which I stopped since I don't know what I'm doing exactly. I also tried the command sudo dpkg -i libc6_2.33-0ubuntu5_amd64.deb, and got the following:
dpkg: regarding libc6_2.33-0ubuntu5_amd64.deb containing libc6:amd64:
 libc6:amd64 breaks fakeroot (<< 1.25.3-1.1ubuntu2~)
  fakeroot (version 1.24-1) is present and installed.
dpkg: error processing archive libc6_2.33-0ubuntu5_amd64.deb (--install): installing libc6:amd64 would break fakeroot, and deconfiguration is not permitted (--auto-deconfigure might help) Errors were encountered while processing: libc6_2.33-0ubuntu5_amd64.deb
I then tried to upgrade libfakeroot using the .deb file and GDebi (I also tried to install libc6 with this tool but the Install button is greyed out): if I check from the terminal the version of this library with apt-cache policy fakeroot I get Installed: 1.24-1 but if I check with sudo apt install ./libfakeroot_1.25.3-1.1_amd64.deb I get:
Note, selecting 'libfakeroot' instead of './libfakeroot_1.25.3-1.1_amd64.deb'
libfakeroot is already the newest version (1.25.3-1.1).
What am I doing wrong?
EDIT 1 The result of uname -a; ls /boot; apt-cache policy linux-headers-5.13.0-051300-generic linux-image-generic libc6 libc-bin libfakeroot is the following:
Linux lorenzo-InfinityBookS 5.13.0-051300-generic #202106272333 SMP Sun Jun 27 23:36:43 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
config-5.13.0-051300-generic  grub                              initrd.img-5.8.0-59-generic  System.map-5.13.0-051300-generic  vmlinuz-5.13.0-051300-generic
config-5.4.0-77-generic       initrd.img                        initrd.img.old               System.map-5.4.0-77-generic       vmlinuz-5.4.0-77-generic
config-5.8.0-55-generic       initrd.img-5.13.0-051300-generic  memtest86+.bin               System.map-5.8.0-55-generic       vmlinuz-5.8.0-55-generic
config-5.8.0-59-generic       initrd.img-5.4.0-77-generic       memtest86+.elf               System.map-5.8.0-59-generic       vmlinuz-5.8.0-59-generic
efi                           initrd.img-5.8.0-55-generic       memtest86+_multiboot.bin     vmlinuz                           vmlinuz.old
linux-headers-5.13.0-051300-generic:
  Installed: (none)
  Candidate: (none)
  Version table:
linux-image-generic:
  Installed: 5.4.0.77.80
  Candidate: 5.4.0.77.80
  Version table:
 *** 5.4.0.77.80 500
        500 http://mirrors.tuxedocomputers.com/ubuntu/mirror/security.ubuntu.com/ubuntu focal-security/main amd64 Packages
        500 http://mirrors.tuxedocomputers.com/ubuntu/mirror/archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
        100 /var/lib/dpkg/status
     5.4.0.26.32 500
        500 http://mirrors.tuxedocomputers.com/ubuntu/mirror/archive.ubuntu.com/ubuntu focal/main amd64 Packages
libc6:
  Installed: 2.31-0ubuntu9.3
  Candidate: 2.31-0ubuntu9.3
  Version table:
 *** 2.31-0ubuntu9.3 100
     2.31-0ubuntu9.2 500
     2.31-0ubuntu9 500
libc-bin:
  Version table:
     2.31-0ubuntu9.2 500
     2.31-0ubuntu9 500
libfakeroot:
  Installed: 1.25.3-1.1
  Candidate: 1.25.3-1.1
  Version table:
 *** 1.25.3-1.1 100
     1.24-1 500
At first we need to revert packages to their default versions from Ubuntu 20.04 LTS repository:
sudo apt-get install --reinstall libc6=2.31-0ubuntu9.2 libc-bin=2.31-0ubuntu9.2
sudo apt-get install --reinstall libfakeroot=1.24-1
Then we need to remove just installed 5.13 kernel as its headers depend on newer libc6 which is not available for Ubuntu 20.04 LTS.
Use command below:
sudo apt-get purge linux-headers-5.13.0-051300 linux-image-unsigned-5.13.0-051300-generic linux-modules-5.13.0-051300-generic
About original USB-Ethernet problem with TP Link U300 I see that it is based on Realtek RTL8153. This chip is supported at least by linux-firmware package. But it hard to give complete instruction without the output journalctl -f and lsusb, lsusb -t.
N0rbert
  • 103,263
