I discovered an instance of dnsmasq running on my fresh install of xubuntu desktop. The general purpose of dnsmasq is known to be a DNS relay and DHCP server. The running process is reported as follows:
/usr/sbin/dnsmasq --no-resolv --keep-in-foreground --no-hosts --bind-interfaces --pid-file=/var/run/sendsigs.omit.d/network-manager.dnsmasq.pid --listen-address=127.0.0.1 --conf-file=/var/run/nm-dns-dnsmasq.conf --cache-size=0 --proxy-dnssec
Looks like it is spawned by network-manager. Contents of mentioned files are:
#cat /var/run/nm-dns-dnsmasq.conf
server=192.168.2.1
In my local network 192.168.2.1 indeed is a DNS server. I cannot understand why this instance of dnsmasq listens on 127.0.0.1 since I see no way to serve DNS relay and DHCP server on 127.0.0.1 interface.
mbaitoff
  • 397
127.0.0.1 is the loopback address, it is not accessible by other machines, just the machine itself. According to the post http://www.stgraber.org/2012/02/24/dns-in-ubuntu-12-04/, this dnsmasq instance exists to improve performance by trying multiple DNS servers if one is too slow.
Lekensteyn
  • 178,446
-1
It is a DNS server and it'd assign IP addresses to machines that request them from your computer. In this case it'd be used by NetworkManager to share your internet connection. Nothing to worry about :)
pietrek
  • 157
