I want to install Ubuntu 12.04 64-bit in a new Dell xps 13.
When I am trying to install appears this message:
speech-dispatcher disabled
and after that I get a black screen.
This is probably unrelated to speech-dispatcher; it's most likely that that's simply the last message you saw before the GUI loaded and failed to display. However, if what you've described is occurring after you've started the installation process and not during boot, please edit your question to indicate this. And if this answer doesn't fix your problem, please edit your question to describe exactly what steps you are following to install and everything that happens in response.
First, you should MD5 test the .iso image you downloaded. If that doesn't check out, you'll have to redownload it and start over. Assuming that does check out, go ahead and test your installation media for defects. If that reveals a problem, then you'll have to burn the CD or write the USB flash drive over again.
If both of those tests show no errors, try setting the nomodeset boot option.
I had the same problem. I was using 13.x version. It shows the message terminating all .. etc
I just hit the enter in the machine, that triggered to reboot the VM and the VM started normally.
