I have a brand new machine comprising
- Motherboard: Gigabyte B560M DS3H
- Processor: Intel Core i9-11900 2.5GHz (Rocket Lake)
After quite some troubleshooting I have managed to install Ubuntu 21.04 on this machine but I still have some problems. Skip to the end for the unresolved questions.
In order to get Ubuntu installed and booting I had to take the following unusual steps:
- To avoid power-off during boot I had to add kernel parameter:
acpi=off. Without that parameter boot fails with messageFailed to look up EFI memory descriptor for 0x.... If I useacpi=htthere is an abrupt hard reset during boot. - The Ubuntu installer failed at the setting up GRUB stage. I was able to manually install grub using the chroot method here except that a) I had to mount my boot partition at
/target/boot/efinot/target/bootand b) I had to use the--no-nvramoption ofgrub-installto avoid anOperation not permittederror. - To get the onboard graphics working above 1024x768 resolution I had to
apt install linux-oem-20.04
Now I can boot the OS but I have two unsolved problems:
- According to
/proc/cpuinfothe OS is only aware of one of my eight CPU cores. - The machine cannot power itself off, I can only power off via a long press on the physical power button.
Does anyone have any idea how to diagnose or fix these problems?
Thanks for any help!
