I am trying to install blueman which seems to have pygtk-2.0 as a dependency. When doing ./configure, it stops here:
configure: error: Package requirements (pygtk-2.0 >= 2.12.0) were not met:
No package 'pygtk-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix.
Alternatively, you may set the environment variables PYGTK_CFLAGS and PYGTK_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details.
Since python-gtk2 is not available through apt, I installed it manually from a package as described here.
Then tried configuring blueman again, but I still get the same error.
Am I missing something?
kanishk
The needed pygtk-2.0.pc file was last available for Ubuntu 18.04 LTS and came from python-gtk2-dev package.
So you have to download and install this development package with dependencies manually by using commands below:
cd ~/Downloads
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/p/pygtk/python-gtk2_2.24.0-5.1ubuntu2_amd64.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/p/pygtk/python-gtk2-dev_2.24.0-5.1ubuntu2_all.deb
sudo apt-get update sudo apt-get install ./python-gtk2-dev_2.24.0-5.1ubuntu2_all.deb ./python-gtk2_2.24.0-5.1ubuntu2_amd64.deb
and then check its registration by pkg-config --list-all | grep pygtk-2.0 .
Also please note that modern Gtk3.0 based version of BlueMan exists in official universe pocket for Ubuntu 20.04 LTS. You can install BlueMan as simple as
sudo apt-add-repository universe
sudo apt-get install blueman
N0rbert
  • 103,263
