I'm installing gravityzone server on my Ubuntu. When I try to install web console it gives me and error.
The problem is it can't install php7.4-imagick. I tried to install it manually and I got this:
Reading package lists... Done
Building dependency tree
php7.4-imagick : Depends: libmagickcore-6.q16-6 (>= 8:6.9.10.2) but it is not going to be installed
Depends: libmagickwand-6.q16-6 (>= 8:6.9.10.2) but it is not going to be installed
Recommends: ghostscript but it is not installable
Recommends: ttf-dejavu-core but it is not installable
Any help?
