So I'm trying to get started with Juju, and tried to do this locally using LXC.
I followed the instructions here: How do I configure juju for local usage?
Unfortunately this doesn't seem to work for me.
status shows the following:
$ juju status
machines:
  0:
    agent-state: running
    dns-name: localhost
    instance-id: local
    instance-state: running
services:
  mysql:
    charm: cs:precise/mysql-1
    relations:
      db:
      - wordpress
    units:
      mysql/0:
        agent-state: pending
        machine: 0
        public-address: null
  wordpress:
    charm: cs:precise/wordpress-0
    exposed: true
    relations:
      db:
      - mysql
    units:
      wordpress/0:
        machine: 0
        open-ports: []
2012-05-10 14:09:38,155 INFO 'status' command finished successfully
As you can see the agent-state is 'pending' and there is no public address where I'm able to access the newly created site. Am I missing something here?
UPDATE: Tried destroying the environment an doing everything again (multiple times). This is the output for debug-log:
~$ juju debug-log
2012-05-11 08:50:23,790 INFO Enabling distributed debug log.
2012-05-11 08:50:23,806 INFO Tailing logs - Ctrl-C to stop.
2012-05-11 08:50:42,338 Machine:0: juju.agents.machine DEBUG: Units changed old:set([]) new:set(['mysql/0'])
2012-05-11 08:50:42,339 Machine:0: juju.agents.machine DEBUG: Starting service unit: mysql/0 ...
2012-05-11 08:50:42,459 Machine:0: unit.deploy DEBUG: Downloading charm cs:precise/mysql-1 to /home/andre/.juju/data/andre-local/charms
2012-05-11 08:50:42,620 Machine:0: unit.deploy DEBUG: Using <juju.machine.unit.UnitContainerDeployment object at 0x9c54b6c> for mysql/0 in /home/andre/.juju/data/andre-local
2012-05-11 08:50:42,648 Machine:0: unit.deploy DEBUG: Starting service unit mysql/0...
2012-05-11 08:50:42,649 Machine:0: unit.deploy DEBUG: Creating master container...
2012-05-11 08:54:33,992 Machine:0: unit.deploy DEBUG: Created master container andre-local-0-template
2012-05-11 08:54:33,993 Machine:0: unit.deploy INFO: Creating container mysql-0...
2012-05-11 08:56:18,760 Machine:0: unit.deploy INFO: Container created for mysql/0
2012-05-11 08:56:19,466 Machine:0: unit.deploy DEBUG: Charm extracted into container
2012-05-11 08:56:19,569 Machine:0: unit.deploy DEBUG: Starting container...
2012-05-11 08:56:22,707 Machine:0: unit.deploy INFO: Started container for mysql/0
2012-05-11 08:56:22,707 Machine:0: unit.deploy INFO: Started service unit mysql/0
2012-05-11 08:56:23,012 Machine:0: juju.agents.machine DEBUG: Units changed old:set(['mysql/0']) new:set(['wordpress/0', 'mysql/0'])
2012-05-11 08:56:23,039 Machine:0: juju.agents.machine DEBUG: Starting service unit: wordpress/0 ...
2012-05-11 08:56:23,154 Machine:0: unit.deploy DEBUG: Downloading charm cs:precise/wordpress-0 to /home/andre/.juju/data/andre-local/charms
2012-05-11 08:56:23,396 Machine:0: unit.deploy DEBUG: Using <juju.machine.unit.UnitContainerDeployment object at 0x9c519cc> for wordpress/0 in /home/andre/.juju/data/andre-local
2012-05-11 08:56:23,620 Machine:0: unit.deploy DEBUG: Starting service unit wordpress/0...
2012-05-11 08:56:23,621 Machine:0: unit.deploy INFO: Creating container wordpress-0...
2012-05-11 08:58:24,739 Machine:0: unit.deploy INFO: Container created for wordpress/0
2012-05-11 08:58:25,163 Machine:0: unit.deploy DEBUG: Charm extracted into container
2012-05-11 08:58:25,397 Machine:0: unit.deploy DEBUG: Starting container...
2012-05-11 08:58:27,982 Machine:0: unit.deploy INFO: Started container for wordpress/0
2012-05-11 08:58:27,983 Machine:0: unit.deploy INFO: Started service unit wordpress/0
This is the result for the status command (with verbose flag):
~$ juju -v status
2012-05-11 08:51:53,464 DEBUG Initializing juju status runtime
2012-05-11 08:51:53,625:4030(0xb7345b00):ZOO_INFO@log_env@658: Client environment:zookeeper.version=zookeeper C client 3.3.5
2012-05-11 08:51:53,625:4030(0xb7345b00):ZOO_INFO@log_env@662: Client environment:host.name=andre-ufo
2012-05-11 08:51:53,625:4030(0xb7345b00):ZOO_INFO@log_env@669: Client environment:os.name=Linux
2012-05-11 08:51:53,625:4030(0xb7345b00):ZOO_INFO@log_env@670: Client environment:os.arch=3.2.0-24-generic-pae
2012-05-11 08:51:53,625:4030(0xb7345b00):ZOO_INFO@log_env@671: Client environment:os.version=#37-Ubuntu SMP Wed Apr 25 10:47:59 UTC 2012
2012-05-11 08:51:53,626:4030(0xb7345b00):ZOO_INFO@log_env@679: Client environment:user.name=andre
2012-05-11 08:51:53,626:4030(0xb7345b00):ZOO_INFO@log_env@687: Client environment:user.home=/home/andre
2012-05-11 08:51:53,626:4030(0xb7345b00):ZOO_INFO@log_env@699: Client environment:user.dir=/home/andre
2012-05-11 08:51:53,626:4030(0xb7345b00):ZOO_INFO@zookeeper_init@727: Initiating client connection, host=192.168.122.1:41779 sessionTimeout=10000 watcher=0xb7780620 sessionId=0 sessionPasswd=<null> context=0x9242ee8 flags=0
2012-05-11 08:51:53,627:4030(0xb6b90b40):ZOO_INFO@check_events@1585: initiated connection to server [192.168.122.1:41779]
2012-05-11 08:51:53,649:4030(0xb6b90b40):ZOO_INFO@check_events@1632: session establishment complete on server [192.168.122.1:41779], sessionId=0x1373ae057d90007, negotiated timeout=10000
2012-05-11 08:51:53,651 DEBUG Environment is initialized.
machines:
  0:
    dns-name: localhost
    instance-id: local
services:
  mysql:
    relations:
      db:
      - wordpress
    units:
      mysql/0:
        machine: 0
  wordpress:
    relations:
      db:
      - mysql
    units:
      wordpress/0:
        machine: 0
Andre
  • 520
I was running into the same error, and with the help of the good folks in #juju, was able to determine that having my firewall turned on on the host machine was blocking zookeeper from connecting back to the host.
Try running:
sudo ufw disable
and then:
sudo juju destroy-environment
and then fire things back up. Also, if this is the first time you're bootstrapping an environment on your machine, note that it takes some time for the initial charm downloading to complete, so give it 15-20 minutes after you deploy a unit.
This is also now an open bug, as juju should be handling this situation automatically.
Jjed
  • 14,064
nathwill
  • 2,643
If this is the first time you've bootstrapped your local environment it will take several (depending on how long it takes to download about 400MB of Server Image data) to build the first master image. In your "data-dir" path (defined in your environments.yaml file) there is a machine-agent.log which describes this process:
2012-05-09 10:04:03,848: juju.agents.machine@INFO: Machine agent started id:0
2012-05-09 10:05:08,175: juju.agents.machine@DEBUG: Units changed old:set([]) new:set(['mysql/0'])
2012-05-09 10:05:08,176: juju.agents.machine@DEBUG: Starting service unit: mysql/0 ...
2012-05-09 10:05:08,222: unit.deploy@DEBUG: Downloading charm cs:precise/mysql-1 to /home/marco/.juju/local/marco-local/charms
2012-05-09 10:05:08,314: unit.deploy@DEBUG: Using <juju.machine.unit.UnitContainerDeployment object at 0x9cccbec> for mysql/0 in /home/marco/.juju/local/marco-local
2012-05-09 10:05:08,375: unit.deploy@DEBUG: Starting service unit mysql/0...
2012-05-09 10:05:08,376: unit.deploy@DEBUG: Creating master container...
A few moments later you'll see the following:
2012-05-09 10:09:40,699: unit.deploy@DEBUG: Created master container marco-local-0-template
2012-05-09 10:09:40,699: unit.deploy@INFO: Creating container mysql-0...
2012-05-09 10:10:31,429: unit.deploy@INFO: Container created for mysql/0
2012-05-09 10:10:31,483: unit.deploy@DEBUG: Charm extracted into container
Which details that several minutes later the master container was created.
Finally, not every "local" boostrap works, try running juju destroy-environment and then re-run juju bootstrap
Marco Ceppi
  • 48,827
I had this same issue. I found in master-customize.log apt-get failures due to corrupt packages in apt-cacher-ng (I'm not sure bit I think this happened because my laptop suspended during the download). I was able to correct the problem by visiting http://localhost:3142/acng-report.html, checking:
  • Validate by file name AND file directory (not recommended),
  • then validate file contents through checksum (SLOW), also detecting corrupt files,
  • then truncate damaged files immediately.
and clicking on Start Scan and/or Expiration. Then I was able to destroy the juju environment and successfully redeploy it.
Instead of disabling ufw, one may try to allow juju's (libvirt) network with:
sudo ufw allow from `ip addr show virbr0|tail -n 1 |cut -d' ' -f 6` to any
Works in my case on Ubuntu 12.04
suside
  • 692
