when I open the software updater this message opens up: not enough free space The upgrade needs a total of 136 M free space on disk '/boot'. Please free at least an additional 45.2 M of disk space on '/boot'. You can remove old kernels using 'sudo apt autoremove', and you could also set COMPRESS=xz in /etc/initramfs-tools/initramfs.conf to reduce the size of your initramfs.
sudo autoremove doesn't work.
what should I do?
thanks and regards
In response to the comments:
Here it is ls /boot:
config-4.15.0-144-generic      memtest86+.elf
config-5.4.0-74-generic        memtest86+_multiboot.bin
grub                           System.map-4.15.0-144-generic
initrd.img                     System.map-5.4.0-74-generic
initrd.img-4.15.0-144-generic  vmlinuz
initrd.img-5.4.0-74-generic    vmlinuz-4.15.0-144-generic
initrd.img.old                 vmlinuz-5.4.0-74-generic
lost+found                     vmlinuz.old
memtest86+.bin
and here df /h:
Filesystem                   Size  Used Avail Use% Mounted on
udev                         1.9G     0  1.9G   0% /dev
tmpfs                        388M  1.8M  386M   1% /run
/dev/mapper/ubuntu--vg-root  913G  9.6G  857G   2% /
tmpfs                        1.9G     0  1.9G   0% /dev/shm
tmpfs                        5.0M  4.0K  5.0M   1% /run/lock
tmpfs                        1.9G     0  1.9G   0% /sys/fs/cgroup
/dev/sda1                    236M  137M   87M  62% /boot
tmpfs                        388M   32K  388M   1% /run/user/1000
user68186
  • 37,461
