14
I'm tring to add a keys (on Kubuntu 12.04)
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys SOMEKEY
and I constantly get
gpg: requesting key 8AC93F7A from hkp server keyserver.ubuntu.com
gpg: keyserver timed out
gpg: keyserver receive failed: keyserver error
I thought my ports are closed. But the following should have made ports 80 and 11371 open:
iptables -A INPUT -p tcp -d 0/0 -s 0/0 --dport 80 -j ACCEPT
iptables -A INPUT -p tcp -d 0/0 -s 0/0 --dport 11371 -j ACCEPT
But I still get timed out.
Edit:
The following solves it:
sudo gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys SOMEKEY
Adobe
  • 3,971
5 Answers5
20
If you see something like this:
W: GPG error: http://archive.canonical.com jaunty Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 40976EAF437D05B5
then add the appropriate key:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 40976EAF437D05B5
You can get a list of repos here: http://repogen.simplylinux.ch (but it is not recommended to add x-org updates - at least be sure to back up You xorg.conf)
If see errors from previous repos - empty your /etc/apt/sources.list.d dir.
Alex
  • 115
Adobe
  • 3,971
This saved my life behind corporate proxy, hope it helps you too:
sudo apt-key adv --keyserver-options http-proxy="http://<username>:<password>@<proxy_server_addr>:<proxy_port>" --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys <key_to_import>
Tanny
  • 160
For me, i removed my custom /etc/apt/source.list (which not including the official ubuntu source) and recovered the origin default one back. And that it done!
陈家胜
  • 101
What helped me:
sudo -E apt-key adv --keyserver-options http-proxy="http://<username>:<password>@<proxy_server_addr>:<proxy_port>" --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys <key_to_import>
Converting the server name to a proper URL as below worked for me.
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys SOMEKEY
sudar
  • 67
