when I try to install it shows this. Help me to get rid of it. I tried to install codeblocks once with dpkg command. I am using ubuntu 20.04
reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
codeblocks-contrib : Depends: libboost-system1.62.0 but it is not installable
Depends: libhunspell-1.4-0 but it is not installable
Depends: libwxgtk3.0-0v5 (>= 3.0.2+dfsg) but it is not installable
Depends: libwxsmithlib0 (= 20.03) but 20.03-3 is to be installed
Depends: codeblocks (= 20.03) but it is not going to be installed
Recommends: valgrind but it is not going to be installed
Recommends: cppcheck but it is not going to be installed
Recommends: cscope but it is not going to be installed
Recommends: cccc but it is not going to be installed
codeblocks-dev : Depends: libcodeblocks0 (= 20.03) but 20.03-3 is to be installed
codeblocks-libwxcontrib0 : Depends: libwxgtk3.0-0v5 (>= 3.0.2+dfsg) but it is not installable
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
