I'm running 21.04, with an nvidia Quadro P400 to drive three HP VH240a monitors. This worked fine for over a year ago when I was running xubuntu, and it seemed to work fine when I switched to ubuntu 21.04 for reasons that had nothing to do with screens displays. The only think I ever noticed after switching distro was that all three screens would sometimes go blank for a couple of seconds; this happened perhaps once per hour.
Anyway, I just rebooted the machine today, and suddenly only one monitor seems to be visible to the system. The "Screen Display" section of settings has no options for multiple screens, and the one screen that is working has been forced from its native resolution to 1024 * 768.
The "Additional Drivers" section of Software and Updates showed that the system was using X.org X server, rather than an nvidia package. I don't need any particular level of performance, so I don't much care which driver I use, as long as it works reliably.
I guess this could be a hardware problem, but coming right after a reboot I suspect a bug related to an update? Normally I suspend the system when I'm done using it, so it probably hadn't been rebooted for a a week or two. How do I investigate this? What additional information do I need?
As per comments the problem was solved by booting to the kernel version previous to the upgrade:
This link also shows you how to make grub always boot to a specific kernel version each time.
