I am newby to ubuntu, trying to install ubuntu-server 20.04. During my 1st installation, the network was working good. Per my memory, there was a "enxxx" item at Network Connections page, but I deleted it somehow when I was messing with it.
For some reasons, I have to reinstall the system, but this time I can't find the item indicating the ethernet card. Worse, I can't get any tool since no access to the Internet after installation, say, sudo apt-get install ifconfig is impossible.
I hv tried edit the netplan /etc/netplan, as the answer suggested. also I'd checked the bios, the mac of the ethernet is there.
Please advise how I can solve this issue, or any hint is most welcome. Thanks.
btw, the newly-installed system even doesn't know auto command.
the regular network connection page
Screen when installing Screen when installing
result for ip a ip a
result for lshw lshw
result for lspci lspci
I can find the ethernet controller with sudo lshw -class Net but can't make it work.
lshw -class Net
for better understanding, here is my lshw -c network and netplan
  *-network UNCLAIMED
       description: Ethernet controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 1f.6
       bus info: pci@0000:00:1f.6
       version: 11
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list
       configuration: latency=0
       resources: memory:53300000-5331ffff
netplan
# Let NetworkManager manage all devices on this system
network:
  version: 2
  renderer: NetworkManager
Lorenz Keel
  • 9,511
This assumes that you're installing Ubuntu Server 20.04...
Confirm that /etc/network/interfaces (if it exists) contains only this:
auto lo
iface lo inet loopback
Confirm that /etc/NetworkManager/NetworkManager.conf contains this:
[ifupdown]
managed=false
We'll change /etc/netplan/*.yaml...
cd /etc/netplan # change directory
ls -al # find the filename
sudo pico the_filename_shown_above.yaml # edit the file
Change this:
network:
  version: 2
To this:
# Let systemd-networkd manage all devices on this system
network:
  version: 2
  renderer: networkd
  ethernets:
    enp0s3:
      dhcp4: true
Save the file.
sudo netplan generate
sudo netplan apply
reboot
heynnema
  • 73,649
