After upgrading from 16.04 to 18.04 right at the end it gave the following message:
The upgrade has completed but there were errors during the upgrade
process.
To continue please press [ENTER]
pressed [ENTER]
Now when I do apt update / apt upgrade I get the following message:
systemd : Depends: libsystemd0 (= 229-4ubuntu21.31) but 237-3ubuntu10.48 is installed
Looking in : https://packages.ubuntu.com/bionic/libs/ It shows the following for libsystemd0 for 18.04 anyway. So I'm not sure why the system believes the dependency should be 229-4ubuntu21.31.
libsystemd0 (237-3ubuntu10.38 [amd64, i386], 237-3ubuntu10 [arm64, armhf, ppc64el, s390x]) [security]
systemd utility library
At the end of apt upgrade it also says:
You might want to run 'apt-get -f install' to correct these.
When I run this I get:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
cgmanager libargon2-0 libcryptsetup12 libgd3 libip4tc0 libjson-c3 libkadm5clnt-mit9 libluajit-5.1-2 libluajit-5.1-common libvpx3 libxpm4 nginx-common
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
upstart
Suggested packages:
graphviz upstart-monitor
The following packages will be REMOVED:
init libpam-systemd systemd systemd-shim systemd-sysv ubuntu-standard
The following NEW packages will be installed:
upstart
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
init systemd-sysv (due to init)
0 upgraded, 1 newly installed, 6 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/392 kB of archives.
After this operation, 18.1 MB disk space will be freed.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
Clearly something quite horrible has happened.
I'm a bit out of my depth here and would appreciate some guidance/next steps.
Thanks
Adding : Output as requested by NOrbert
nexargi@server-02:~$ apt-cache policy systemd libsystemd0 init systemd-sysv
systemd:
Installed: 229-4ubuntu21.31
Candidate: 229-4ubuntu21.31
Version table:
*** 229-4ubuntu21.31 500
500 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
100 /var/lib/dpkg/status
229-4ubuntu21.27 500
500 http://us.archive.ubuntu.com/ubuntu xenial-security/main amd64 Packages
229-4ubuntu4 500
500 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
libsystemd0:
Installed: 237-3ubuntu10.48
Candidate: 237-3ubuntu10.48
Version table:
*** 237-3ubuntu10.48 100
229-4ubuntu4 500
init:
Installed: 1.29ubuntu4
Candidate: 1.29ubuntu4
Version table:
*** 1.29ubuntu4 500
1.29ubuntu1 500
systemd-sysv:
Version table:
229-4ubuntu4 500
Edited to include links to Pastebin as requested by NOrbert: @NOrbert please note that these were taken immediately after 16.04 was restored. i.e. They represent 16.04 state BEFORE any release-upgrade.
grep -r ^deb /etc/apt --include=*.list https://pastebin.com/85qJeYws
apt-cache policy https://pastebin.com/q8S47v1e
dpkg -l https://pastebin.com/Zp999iuF
