after reading related threads I realized, how brittle duplicity is for backups. Anyway, for some strange reasons deja-dup stopped working:
  • first I got an error similar to this (probably made some small change to keyring / seahorse / gpg before, but I cannot remember exactly
  • I then apt-get removed deja-dup and duplicity and
  • snap installed latest version of both
Now I'm stuck with a new "known" error:
Backup keeps asking for Encryption Password while restoring
which nobody (including me) was really able to recover from.
Here is the command line output when I start the 'snap'-ed deja-dup from command line using
export DEJA_DUP_DEBUG=1
deja-dup  --backup
here is the error message:
UPLICITY: . Found primary backup chain with matching signature chain:
DUPLICITY: . -------------------------
DUPLICITY: . Chain start time: Thu May 27 11:42:53 2021
DUPLICITY: . Chain end time: Thu Jun 24 13:00:50 2021
DUPLICITY: . Number of contained backup sets: 5
DUPLICITY: . Total number of contained volumes: 1933
DUPLICITY: .  Type of backup set:                            Time:      Num volumes:
DUPLICITY: .                 Full         Thu May 27 11:42:53 2021              1817
DUPLICITY: .          Incremental         Wed Jun  2 17:49:47 2021                 3
DUPLICITY: .          Incremental         Thu Jun  3 03:32:43 2021                 2
DUPLICITY: .          Incremental         Thu Jun 24 12:04:03 2021               110
DUPLICITY: .          Incremental         Thu Jun 24 13:00:50 2021                 1
DUPLICITY: . No orphaned or incomplete backup sets found.
DUPLICITY: INFO 1 DUPLICITY: . PASSPHRASE variable not set, asking user.
DUPLICITY: DEBUG 1 DUPLICITY: . Releasing lockfile b'/home/myUsername/snap/deja-dup/common/.cache/deja-dup/e9d3b7f870b518ba61d7edb618232bb5/lockfile'
DUPLICITY: DEBUG 1 DUPLICITY: . Removing still remembered temporary file /home/myUsername/snap/deja-dup/common/.cache/deja-dup/tmp/duplicity-fyu_uk0c-tempdir/mkstemp-slki6otd-1
DUPLICITY: ERROR 30 EOFError DUPLICITY: . Traceback (innermost last): DUPLICITY: . File "/snap/deja-dup/427/bin/duplicity", line 117, in <module> DUPLICITY: . with_tempdir(main) DUPLICITY: . File "/snap/deja-dup/427/bin/duplicity", line 103, in with_tempdir DUPLICITY: . fn() DUPLICITY: . File "/snap/deja-dup/427/lib/python3.8/site-packages/duplicity/dup_main.py", line 1535, in main DUPLICITY: . do_backup(action) DUPLICITY: . File "/snap/deja-dup/427/lib/python3.8/site-packages/duplicity/dup_main.py", line 1610, in do_backup DUPLICITY: . config.gpg_profile.passphrase = get_passphrase(1, action) DUPLICITY: . File "/snap/deja-dup/427/lib/python3.8/site-packages/duplicity/dup_main.py", line 177, in get_passphrase DUPLICITY: . pass1 = getpass_safe(_(u"GnuPG passphrase:") + u" ") DUPLICITY: . File "/snap/deja-dup/427/lib/python3.8/site-packages/duplicity/dup_main.py", line 74, in getpass_safe DUPLICITY: . return getpass.getpass(message) DUPLICITY: . File "/snap/deja-dup/427/usr/lib/python3.8/getpass.py", line 91, in unix_getpass DUPLICITY: . passwd = fallback_getpass(prompt, stream) DUPLICITY: . File "/snap/deja-dup/427/usr/lib/python3.8/getpass.py", line 126, in fallback_getpass DUPLICITY: . return _raw_input(prompt, stream) DUPLICITY: . File "/snap/deja-dup/427/usr/lib/python3.8/getpass.py", line 148, in _raw_input DUPLICITY: . raise EOFError DUPLICITY: . EOFError DUPLICITY: .
my current snap versions are:
deja-dup 42.7 duplicity 0.8.19
mcExchange
  • 3,398
Problem was that I had used different passwords for backups and duplicity did not warn me when doing so. So in order to fix it I had to delete files with the different password in use. It's explained here
mcExchange
  • 3,398
