I am still getting the message 'Failed to hibernate system via logind: Sleep verb "hibernate" not supported' when I use the command 'sudo systemctl hibernate' even after following the instructions found here: How to hibernate with swapfile. I am running Ubuntu 20.04 on my Thinkpad L470 with 16GB of RAM. Following the instructions in the link above, I created a /swapfile corresponding to the size of my RAM. If there is anything else I need to do please help.
Do the instructions here work? How to enable the hibernate option in Ubuntu 20.04?
I assume you have a swap partition ready to use. (If you have a swap file you cannot hibernate) Install
pm-utilsandhibernate:
$ sudo apt install pm-utils hibernateThen:
$ cat /sys/power/stateYou should see:
none freeze mem diskThen run:
$ grep swap /etc/fstabCopy the UUID value. You will need it later. Then run:
$ sudo nano /etc/default/grub(or your favourite editor if not nano). Change the line that says
none GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"so that it instead says:
none GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=YOUR_VALUE"Then, after saving the file and quitting the text editor, run:
$ sudo update-grubTo test it, run:
$ sudo systemctl hibernateRight now no GNOME extension is working to have the hibernate option back in the system menu.
Tested on Ubuntu 20.04 Kernel 5.4.0-31 on my Lenovo Thinkpad X1 Carbon.
