14
I updated my system using:
sudo apt-get update && sudo apt-get upgrade
And then ran the following to install python3.9:
sudo apt-get install python3.9
Which yields output:
Reading package lists... Done
Building dependency tree
python3.9 is already the newest version (3.9.5-3~20.04.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
However, when I run python3 -V it still tells me I am on 3.8.5. How can I fix this?
a6623
  • 259
You can run python3.9 with the command
python3.9
(instead of the command python or python3)
It is not a good idea to change the default version of python3 to python3.9, as that may break your Ubuntu installation. Instead, manually call it with python3.9.
15
In addition to explicitly specifying the python3.9 and working with it globally as explained in Archisman Panigrahi answer ... You can create an isolated virtual environment where python3 -V will report Python 3.9.
This feature can be installed for Python3 like so:
sudo apt install python3-venv
To make a Python3.9 virtual environment, you would first create a directory and cd to it like so:
mkdir my_env && cd my_env
Then, create a new Python3.9 virtual environment inside the directory like so:
python3.9 -m venv env
To use this environment, activate it like so:
source env/bin/activate
Your shell prompt will show (env) like so:
(env) $
During this, python3 -V will report Python 3.9 and commands, module installs or modifications will be contained locally in this virtual environment.
When you are done, deactivate this Python3.9 virtual environment like so:
deactivate
Raffa
  • 34,963
Consider installing Python with Anaconda or Miniconda (I recommend Miniconda). Conda lets you manage different Python versions easily with virtual environments.
sudo wget -c https://repo.anaconda.com/miniconda/Miniconda3-latest-Linux-x86_64.sh
sudo chmod +x Miniconda3-latest-Linux-x86_64.sh
./Miniconda3-latest-Linux-x86_64.sh
Press enter until it asks for "yes" or "no", then type "yes" to accept the terms of use.
If you're using a shell other than bash, type:
conda init <SHELL_NAME> (Supported shells include: fish, tcsh, xonsh, zsh)
Close and open the terminal. Type conda activate to activate the (base) conda environment.
Create a Python 3.9.5 environment, and name it whatever you like:
conda create -n myenv python=3.9.5
Once created, you can activate and use that Python environment:
conda activate myenv
When finished, you can deactivate your environment with:
conda deactivate
Any packages you install with pip or conda will be local to whatever environment you're using, so you don't have to worry about package conflicts. Just don't install everything in your (base) environment, because anything installed in (base) will get copied to new conda environments you create.
Sources:
Setting up Miniconda on Ubuntu
Conda Cheat Sheet
Anaconda Docs
bug_spray
  • 251
