I’m turning GNOME animations off via the following command in the terminal:
gsettings set "org.gnome.desktop.interface" "enable-animations" "false"
This works the very first time. After that, after every fresh boot, the effect is gone. I have to repeat changing the setting. And that’s not even enough:
Just repeating the same command is not sufficient. I first have to invert the setting, then put in the setting that I actually want again:
gsettings set "org.gnome.desktop.interface" "enable-animations" "true"
The above is what I need after every boot. Why is that?
How I see the results? In the “gedit” text editor, smooth scrolling depends on animations being enabled.
Edit 1: Where can I see the (lack of) effect from this option after a reboot? In gedit (long text document) and Nautilus (longer list of folders and files in default view), smooth scrolling is disabled immediately after setting the option, but is enabled again after a reboot. On the contrary, in the “Applications” list opened from the dock, the open/close animation for the list remains disabled after a reboot, and smooth scrolling in the list remains disabled as well.
caw
  • 456
