I download Unbuntu and I’m having trouble to boot into Windows 10, my main c drive I need help please
Jeremy
  • 2,926
There's a few things that might have happened.
It's possible that you've accidentally deleted the Windows partition when you installed Ubuntu. Open up gparted and see if you can still see the Windows partitions (usually you'll see at least one big NTFS partition). If you can't see them there, then check whether the current Ubuntu install is where you would have expected Windows to be (i.e. if you only have one hard drive and it has Ubuntu taking up all the space, then you've probably installed Ubuntu over the top of Windows).
If you can see the Windows partitions, then it's also possible that it's only a boot-loader issue. Usually when Ubuntu installs, it looks for other operating systems and includes them in the boot menu. If this hasn't worked, the Boot Repair application can help. You can install and run it using the following commands:
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
The tool is pretty self explanatory, but the link I provided has more information. After running boot-repair hopefully you'll be able to boot back into Windows.
Jeremy
  • 2,926
-1
I believe Ubuntu overwrites Windows boot loader.Look up fix master boot record MBR for windows 10. You will need a usb drive with Windows 10. Or use the ubuntu Boot-Repair software. Then in the ubuntu terminal use "os-prober" to find windows and "nano /etc/default/grub" if you want to change timeout of grub from 5 to 10. Apply changes with "sudo update-grub".
Link for fixing windows 10 master boot record. https://www.partitionwizard.com/partitionmanager/windows-mbr-fix.html
