Have an unused laptop that I want to run Ubuntu on (and leave in a corner to run various scripts). I installed Ubuntu Desktop and a wired connection worked for a while then just stopped working (wifi works). I re-did a fresh install and it works for a while then stops working. There is nothing wrong with the cable or connection; I tried two different ethernet cables on two different laptops as well, there is no issue with the router, cable or internet connectivity.
I have tried everything I have come across on Google and these forums but nothing has worked. It just says "Cable Unplugged". It has on one occasion reconnected but goes away again.
Anyone encountered this before and have a solution? Any help is greatly appreciated.
Here is some output.
sudo lshw -c network
-network description: Wireless interface product: QCA9565 / AR9565 Wireless Network Adapter vendor: Qualcomm Atheros physical id: 0 bus info: pci@0000:03:00.0 logical name: wlp3s0 version: 01 serial: 40:f0:2f:74:52:ec width: 64 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless configuration: broadcast=yes driver=ath9k driverversion=5.8.0-55-generic firmware=N/A ip=192.168.1.77 latency=0 link=yes multicas resources: irq:18 memory:f7900000-f797ffff memory:f7980000-f798ffff -network description: Ethernet interface product: QCA8171 Gigabit Ethernet vendor: Qualcomm Atheros physical id: 0 bus info: pci@0000:04:00.0 logical name: enp4s0 version: 10 serial: 0c:54:a5:1d:f4:6e capacity: 1Gbit/s width: 64 bits clock: 33MHz capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiati configuration: autonegotiation=on broadcast=yes driver=alx driverversion=5.8.0-55-generic latency=0 link=no multicast=yes port=tw resources: irq:19 memory:f7800000-f783ffff ioport:d000(size=128)
figs
Turns out it was a loose connection in the hardware as a USB to Ethernet adapter is working flawlessly so far, not a software issue. Grrr, spent a lot of time on this but such is life. Appreciate the help everyone
figs
