I've completely purged Skype from ubuntu 20.04 since I kept receiving the following error whenever apt-get update and couldn't find a solution:
Err:4 https://repo.skype.com/deb stable InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1F3045A5DF7587C3
Reading package lists... Done W: GPG error: https://repo.skype.com/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1F3045A5DF7587C3 E: The repository 'https://repo.skype.com/deb stable InRelease' is not signed.
Yet, I still receive the above error when apt-get update even though I've removed the public key, all Skype installs and Snaps.
What is going on?
SOVLED:
sudo rm /etc/apt/sources.list.d/skype-stable.list
sudo rm /etc/apt/sources.list.d/skype-stable.save
1F3045A5DF7587C3 key is no longer valid which can be removed using apt-key del command.
Step 1: Delete the invalid key:
sudo apt-key del 1F3045A5DF7587C3
If anyone has Skype running but facing the signature verification error while running sudo apt update command then continue with the below steps.
Step 2: Add a valid key:
curl https://repo.skype.com/data/SKYPE-GPG-KEY | sudo apt-key add -
Step 3: Run the below commands:
sudo apt update
sudo apt upgrade
This error should be removed now!
Muniraj
  • 889
