I am able to open pdf files with evince, but I can't open any link in the browser.
I have found this link from years ago:
Hyperlinks clicked in evince document viewer are not opening, any ideas on how to fix?
but my /etc/apparmor.d/abstractions/ubuntu-helpers file does not contain the mentioned reference "/usr/lib*/{,*/} Pixr,"
# Lenient profile that is intended to be used when 'Ux' is desired but
# does not provide enough environment sanitizing. This effectively is an
# open profile that blacklists certain known dangerous files and also
# does not allow any capabilities. For example, it will not allow 'm' on files
# owned be the user invoking the program. While this provides some additional
# protection, please use with care as applications running under this profile
# are effectively running without any AppArmor protection. Use this profile
# only if the process absolutely must be run (effectively) unconfined.
# Usage:
# Because this abstraction defines the sanitized_helper profile, it must only
# be #included once. Therefore this abstraction should typically not be
# included in other abstractions so as to avoid parser errors regarding
# multiple definitions.
# Limitations:
# 1. This does not work for root owned processes, because of the way we use
#    owner matching in the sanitized helper. We could do a better job with
#    this to support root, but it would make the policy harder to understand
#    and going unconfined as root is not desirable any way.
# 2. For this sanitized_helper to work, the program running in the sanitized
#    environment must open symlinks directly in order for AppArmor to mediate
#    it. This is confirmed to work with:
#     - compiled code which can load shared libraries
#     - python imports
#    It is known not to work with:
#     - perl includes
# 3. Sanitizing ruby and java
# Use at your own risk. This profile was developed as an interim workaround for
# LP: #851986 until AppArmor utilizes proper environment filtering.
profile sanitized_helper { #include <abstractions/base> #include <abstractions/X>
Allow all networking
network inet, network inet6,
Allow all DBus communications
#include <abstractions/dbus-session-strict> #include <abstractions/dbus-strict> dbus,
Needed for Google Chrome
ptrace (trace) peer=**//sanitized_helper,
Allow exec of anything, but under this profile. Allow transition
to other profiles if they exist.
/{usr/,usr/local/,}{bin,sbin}/* Pixr,
Allow exec of libexec applications in /usr/lib* and /usr/local/lib*
/usr/{,local/}lib/{,/} Pixr,
Allow exec of software-center scripts. We may need to allow wider
permissions for /usr/share, but for now just do this. (LP: #972367)
/usr/share/software-center/* Pixr,
Allow exec of texlive font build scripts (LP: #1010909)
/usr/share/texlive/texmf{,-dist}/web2c/{,*/} Pixr,
While the chromium and chrome sandboxes are setuid root, they only link
in limited libraries so glibc's secure execution should be enough to not
require the santized_helper (ie, LD_PRELOAD will only use standard system
paths (man ld.so)).
/usr/lib/chromium-browser/chromium-browser-sandbox PUxr, /usr/lib/chromium{,-browser}/chrome-sandbox PUxr, /opt/google/chrome{,-beta,-unstable}/chrome-sandbox PUxr, /opt/google/chrome{,-beta,-unstable}/google-chrome Pixr, /opt/google/chrome{,-beta,-unstable}/chrome Pixr, /opt/google/chrome{,-beta,-unstable}/{,*/}lib.so{,.*} m,
Full access
/ r, /** rwkl, /{,usr/,usr/local/}lib{,32,64}/{,*/}.so{,.*} m,
Dangerous files
audit deny owner //* m, # compiled libraries audit deny owner //.py r, # python imports }
Any idea?
Menks
  • 43
I love evince, and it's great as a quick viewer for an occasional document, but if you do any kind of collection and organization of documents, then I'd recommend downloading calibre and using its built-in ebook viewer. The calibre is cross-platform and FOSS and can help you build a library of books (including PDF, ePubs, html, and lots of special formats) and help transfer these books to a long list of other devices with their idiosyncrasies.
Maybe that's more than you need, but it's worth a try.
https://calibre-ebook.com/download_linux
Back to the viewer, it's typically invoked from calibre, but can be opened standalone program as
/opt/calibre/bin/ebook-viewer
You can even add it as a favorite on your toolbar.
My solution is therefore not trying to mend a broken installation of evince (which I tried without luck) to open hyperlinks within a PDF, but take your reading to the next step and enjoy other lightweight more robust reading tools and other formats such as ePub, too.
mondotofu
  • 817
