I had a 4 GB RAM in the Ubuntu system, then I bought again a 4 GB RAM, but this time the new RAM is not detectable by OS as well as BIOS.
My motherboard supports 8 GB RAM 800/1067 MHz RAM
old ram -> 4 GB 1600 MHz detectable
new ram -> 4 GB 1600 MHz non detectable
free -m shows only 4 GB of RAM.
lshw command also tells that only 4 GB RAM is plugged that is the old one.
FedKad
  • 13,420
If both cards are the same then the problem is most likely going to be hardware rather than software. if the machine has another slot, try it in there. check the slot you are inserting the card in. look for dirt, dust, or debris. Make sure the card is inserted correctly, usual reasons of failed BIOS detection are:
  1. the card is bad.
  2. the slot or motherboard is bad.
  3. it is not inserted correctly.
  4. wrong card type.
if possible, try the card in another machine. Make sure the card is not for a MAC if it is going in a PC motherboard. And Vice Versa.
Also, free -h gives an output that is a little easier to read.
zx485
  • 2,865
