I am installing MySQL 8.0 in Ubuntu 20.04, but I am facing an unmet dependencies issue.
First I run the command
wget https://dev.mysql.com/get/mysql-apt-config_0.8.16-1_all.deb
it successfully downloaded the package.
Second command
sudo dpkg -i mysql-apt-config_0.8.16-1_all.deb
This command also successfully ran.
Third command
sudo apt-get update
Fourth command
sudo apt install mysql-client mysql-community-server mysql-server
After this command I am getting these issues.
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libmysqlclient21 : Depends: mysql-common (>= 8.0.25-1ubuntu21.04) but 5.8+1.0.5ubuntu2 is installed
Depends: mysql-community-client-plugins (= 8.0.25-1ubuntu21.04) but it is not installable
Depends: libc6 (>= 2.33) but 2.31-0ubuntu9.1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried with sudo apt --fix-broken install, and this appeared:
Correcting dependencies... failed.
libmysqlclient21 : Depends: mysql-common (>= 8.0.25-1ubuntu20.04) but 5.8+1.0.5ubuntu2 is installed
Depends: mysql-community-client-plugins (= 8.0.25-1ubuntu20.04) but it is not installable
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.Reading package lists... Done
E: Unable to correct dependencies
