I'm a new Ubuntu user, and when I try to run sudo apt update, it returns the following errors.
Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
Err:2 http://archive.ubuntu.com/ubuntu focal InRelease
Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
Err:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable)
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable)
W: Some index files failed to download. They have been ignored, or old ones used instead.
Can you help me to solve this problem?
I'm using WSL 2 and Windows 10 using AMD graphic.
