I'm looking to capture the output of a shell script execution in real time to enrich it with information giving the date and time.
To illustrate, I have for example a script of this type that I must not modify:
#!/bin/bash
for i in 2 3 1
do
  echo "Waiting for $i seconds ..."
  sleep $i
done
The script produces the following output:
Waiting for 2 seconds ...
Waiting for 3 seconds ...
Waiting for 1 seconds ...
I am trying to produce the output of the type:
2021-06-16 11:44:48 [INFO] Waiting for 2 seconds ...
2021-06-16 11:44:50 [INFO] Waiting for 3 seconds ...
2021-06-16 11:44:53 [INFO] Waiting for 1 seconds ...
I use the following shell functions for formatting in a script that runs my initial script:
function log {
   echo `date +%Y-%m-%d" "%H:%M:%S`" $@"
   if [ "$LOGFILE" != "" ]
   then
      echo `date +%Y-%m-%d" "%H:%M:%S`" $@" >>$LOGFILE
   fi
function loginf { log "[INFO] $@" }
I manage very well with a while loop on a read to capture the output of my script, but I get all the lines at the same time (end of its execution) and therefore all lines have the same datetime. I try to get the lines each time the script produces a line and not at the end of the execution.
pLumo
  • 27,991
The ts command from package moreutils does precisely what you are looking for:
./script.sh | ts
It has various options for formatting the time stamp. For instance,
ts '%F %T [INFO]'
will give you the exact format you use in your question.
zwets
  • 12,770
  • 37
  • 46
You can either use ts:
./your_script.sh | ts
Of, if you need something portable that works on systems where ts is not installed, you can do that in a simple while loop using the built-in read command:
./your_script.sh | while read line; do echo "$(date +'%Y-%m-%d %H:%M:%S') [INFO] $line"; done
vog
  • 127
