Problem
I can't install libpq-dev in ubuntu 20.04.2
I ran this command:
$ sudo apt-get update
$ sudo apt-get install libpq-dev
then I got errors bellow.
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libpq-dev: Depends: libpq5 (= 12.7-0ubuntu0.20.04.1) but 13.3-1.pgdg20.04 + 1 is to be installed E: Unable to correct problems, you have held broken packages.
Then I try to install the library directly with this command:
$  sudo apt-get install libpq5=12.7-0ubuntu0.20.04.2
I got this error:
Reading package list ... Done
Creating dependency tree
Reading status information ... Done
E: The version «12.7-0ubuntu0.20.04.2» was not found for «libpq5»
Status
Ubuntu version
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.2 LTS
Release:    20.04
Codename:   focal
Kernel version
$ uname -a
Linux IdeaPad-S340-15API 5.8.0-55-generic #62~20.04.1-Ubuntu SMP Wed Jun 2 08:55:04 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Updated
$ apt-cache policy libpq-dev libpq5
libpq-dev:
  Installed: (none)
  Candidate: 12.7-0ubuntu0.20.04.1
  Version table:
     12.7-0ubuntu0.20.04.1 500
        500 http://security.ubuntu.com/ubuntu focal-security / main amd64 Packages
        500 http://archive.ubuntu.com/ubuntu focal-updates / main amd64 Packages
     12.2-4 500
        500 http://archive.ubuntu.com/ubuntu focal / main amd64 Packages
libpq5:
  Installed: 13.3-1.pgdg20.04 + 1
  Candidate: 13.3-1.pgdg20.04 + 1
  Version table:
 *** 13.3-1.pgdg20.04 + 1 500
        500 https://ftp.postgresql.org/pub/pgadmin/pgadmin4/apt/focal pgadmin4 / main amd64 Packages
        100 / var / lib / dpkg / status
     13.2-1.pgdg20.04 + 1 500
     13.1-1.pgdg20.04 + 1 500
     13.0-1.pgdg20.04 + 1 500
     12.4-1.pgdg20.04 + 1 500
     12.3-1.pgdg20.04 + 1 500
     12.2-4 500
Developer
  • 111
