I checked out the Multiple websites on nginx, one IP but I have a small different situation.
I want to host three websites (one for thelounge and other two is ASP.NET Core web app which listens on different ports (5002, respectively 5003)) on same server (same IP address) but on different subdomains.
So, I bought domain from namecheap and I configured domain for the lounge like in picture:
I followed from Thomas Ward's answer step by step but I don't know for .net core web apps which listens different ports. I created service, kestrel service for .net core app in /etc/systemd/system/myapp.service
[Unit]
Description=my app
[Service]
WorkingDirectory=/home/anuser
ExecStart=/usr/bin/dotnet /home/anuser/MyApp.Web.dll
Restart=always
Restart service after 10 seconds if the dotnet service crashes:
RestartSec=10
KillSignal=SIGINT
SyslogIdentifier=info-editor
User=anuser
Environment=ASPNETCORE_ENVIRONMENT=Production
Environment=DOTNET_PRINT_TELEMETRY_MESSAGE=false
[Install]
WantedBy=multi-user.target
I activated above service and I ran it. All good, the website is active.
When trying to access editor.xxx.xxx then it redirects to first website (the lounge).
the nginx conf for thelounge (chat.xxxxx.conf) :
server {
server_name chat.xxxxx.xxxxx;
set $upstream 127.0.0.1:9000;
location / {
proxy_pass_header Authorization;
proxy_pass http://$upstream;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_http_version 1.1;
proxy_set_header Connection "";
proxy_buffering off;
client_max_body_size 0;
proxy_read_timeout 36000s;
proxy_redirect off;
and for .net core web app (editor.xxxxx.conf)
server {
server_name editor.xxxxx.xxxx
set $upstream 127.0.0.1:5002;
location / {
proxy_set_header Connection “”;
proxy_redirect off;
listen 80;
Of course I used ln command to make symbolic link to /sites-enabled
I restarted also nginx. But still redirects to thelounge
