Please help me install glibc 2.32. Running 20.04.
If you need glibc version other than the one shipped with ubuntu, one way is to install manually to a temp location in your $HOME. (installing in /usr would mess up with existing glibc in case something goes wrong)
mkdir $HOME/glibc/ && cd $HOME/glibc
wget http://ftp.gnu.org/gnu/libc/glibc-2.32.tar.gz
tar -xvzf glibc-2.32.tar.gz
mkdir build
mkdir glibc-2.32-install
cd build
~/glibc/glibc-2.32/configure --prefix=$HOME/glibc/glibc-2.32-install
make
make install
Now you should have glibc 2.32 installed in the installation directory.
You may check with ~/glibc/glibc-2.32-install/bin/ldd --version
- 271
Building on Shalini's answer,
#!/bin/bash
SOFTWARE_NAME=$1
SOFTWARE_VERSION=$2
export DOWNLOAD_INSTALL_DIR=$SOFTWARE_NAME-$SOFTWARE_VERSION-download-install
if [ -f $DOWNLOAD_INSTALL_DIR ];
then
rm -fr $DOWNLOAD_INSTALL_DIR
echo "Remove $DOWNLOAD_INSTALL_DIR"
fi
mkdir $HOME/$DOWNLOAD_INSTALL_DIR/ && cd $HOME/$DOWNLOAD_INSTALL_DIR
echo "Current directory at $PWD"
export DOWNLOADED_TAR=$HOME/$DOWNLOAD_INSTALL_DIR/$SOFTWARE_NAME-$SOFTWARE_VERSION.tar.gz
if [ ! -f $DOWNLOADED_TAR ]; then
wget https://ftp.gnu.org/gnu/$SOFTWARE_NAME/$SOFTWARE_NAME-$SOFTWARE_VERSION.tar.gz -P $HOME/$DOWNLOAD_INSTALL_DIR
echo "Software is downloaded: $SOFTWARE_NAME, version = $SOFTWARE_VERSION "
else
echo "Software is ALREADY downloaded: $SOFTWARE_NAME, version = $SOFTWARE_VERSION at $DOWNLOADED_TAR"
fi
tar -xvzf $DOWNLOADED_TAR -C $HOME/$DOWNLOAD_INSTALL_DIR
mkdir $HOME/$DOWNLOAD_INSTALL_DIR/build
export SOURCE_DIR=$HOME/$DOWNLOAD_INSTALL_DIR/$SOFTWARE_NAME-$SOFTWARE_VERSION-install
mkdir $SOURCE_DIR
cd $HOME/$DOWNLOAD_INSTALL_DIR/build
~/$DOWNLOAD_INSTALL_DIR/$SOFTWARE_NAME-$SOFTWARE_VERSION/configure --prefix=$SOURCE_DIR
make
make install
export SOFTWARE_PATH=$HOME/$DOWNLOAD_INSTALL_DIR/$SOFTWARE_NAME-$SOFTWARE_VERSION-install/bin/$SOFTWARE_NAME
if [ -f $SOFTWARE_PATH ]; then
echo "Software is found: $SOFTWARE_NAME, version = $SOFTWARE_VERSION at $SOFTWARE_PATH"
mv $SOFTWARE_PATH $GRAND_ROOT_BIN
fi
You can use the script like so bash script-name.sh bison 3.8 for downloading GNU's bison with version number 3.8.
- 111
