I had this problem when i installed Ubuntu 20.04, i manage to solve it by installing Ubuntu again , and installing old drivers. Now a couple months later, i suspend my computer and get a black screen after i come back.
uname -a
Linux noblepc 5.8.0-55-generic #62~20.04.1-Ubuntu SMP Wed Jun 2 08:55:04 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Nvidia Driver - 460.80 Cant install old drivers , without them getting updated automatically!
GPU - GTX 1050
What is strange is that i had this problem solved , and for no reason it came back, and now i cant manage to solve the problem , even after a bunch of solutions.
Error
Nvidia-Modeset: Failed to allocate display engine core DMA push buffer!
Nvidia-Modeset: GPU 0: Display engine push buffer channel allocation failed 0x65
Edit:
I Managed to solve this problem installing Driver-server
as told previously
If you have only 2 GB of SWAP and the computer attempts to hibernate you'll get it frozen for sure. Your computer has 4GB of RAM, 8GB of RAM or more for sure.
In this example I have create a VM with Virtual Box with 3.3GB of RAM and 2GB of swap and forced hibernation and sleep. Try to locate in your logs if you have something like this:
cat /var/log/syslog | grep -i "hibern\|suspen"
If you find messages like hibernation is likely your computer is attempting to hibernate, and with you swap memory this will almost ever cause a crash explaining your black screen after trying to resume.
This is cause by insufficient swap memory to map the RAM memory.
Sleep keeps the computer on, spending a very little amount of energy to keep what is in RAM memory.
Hibernate swaps all the RAM memory contents to the swap disk and completely shutdowns the computer, spending no energy until it is turned on.
Cheers
Carles Mateo
  • 1,647
I had the same issue and resolved it by installing nvidia-450-server driver as suggested in this post
sudo apt purge nvidia-*
sudo apt autoremove
sudo apt install nvidia-driver-450-server
Richard
  • 102
I have an XMG neo 15 m20 with an RTX 2070 and I struggled with this problem for months after a kernel update in november 2021.
The only thing that worked for me -and I tried a lot of stuff- was switching to discrete-graphics-only mode in the BIOS. It was set to "msHybrid" and I switched it to "dGPU". I think it's an ACPI power mangement issue. I still haven't measured the inpact of using dGPU only on battery life.
