fellow Linuxeers! So, I've had this problem recently when I tried to remove Oracle's Java 7 after it didn't want to work correctly. So, when I tried to:
sudo apt-get purge oracle-java7-install
I get this error at the end of the code:
dpkg: error processing oracle-java7-installer (--configure):
subprocess installed post-installation script returned error exit status 1
No apport report written because MaxReports is reached already
Errors were   encountered while processing:
With no other errors in the output. Now why can't I remove the files? It really is an annoying problem, because every time I install/remove something in the terminal the error shows up. Help? Thanks on forehand!
Alvar
  • 17,038
SgtCedric
  • 39
First I purge the java installer PPA using following commands:
sudo rm oracle-java7-installer*
sudo apt-get purge oracle-java7-installer
Than I signed in to technet.oracle.com using my account ID (registration is free to oracle.com)
I then added the PPA, and this time, it was a success.
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java7-installer
I was able to successfully download from oracle.com. I guess sign-in worked.
Anees
  • 31
I have resolved that issue by visiting the below link:
http://ubuntuforums.org/showthread.php?t=1977483
Balajee G
  • 29
